My radiator keeps blowing
W210 e55 amg
I have a 1999 e55 amg now my radiator blew so I changed it and not even an hour later same thing happened again what should I do what is causing this I don't want to install a radiator and have blow on me again they are expensive someone plz help me
Could be a few things..Did you get a decent radiator or a cheap Ebay knockoff made in China?...In very rare cases a blown HG will allow compression into the cooling system and cause excessive pressure...My bet is you just got a bad radiator...Send the other back and demand a refund.
W210 e55 amg
Another hint of a bad HG would be your radiator hoses swelling up soon after starting(when cold)..It would be much more common for you to have gotten a faulty radiator than having a blown HG on this particular engine...Ive gotten plenty of bad radiators over the years.Consider that barely any of them are made of aluminum and instead cheap plastic..Even the Behr is cheaply made..I just changed my factory unit at 67k with a new Behr unit..My car has been serviced religiously with Blue MB coolant..
