Cylinder 8 Misfire
As the title states, I'm having a misfire in cylinder 8. My indie shop diagnosed it and told me it could be the plug, wire or the coil. So I came to the conclusion that I will replace the plugs with Bosch 7422's and wires with Magnecor wires myself. My question is, where is cylinder 8 located? So I can replace the coil. I don't want to replace all coils because they cost about 130 each. If anybody has a diagram or point me where I can find one, it's much appreciated
Thanks in advance!
-You can diagnose the problem it's fairly easy, just move the coil to another cylinder. If the misfire moves to the other cylinder you know it's defective.
-How are the valve covers? a leaking cover could let oil foul the spark plugs.
You can see cylinder numbers on the engine, 1-4 passenger side, 5-8 driver side. 4 & 8 are closest to firewall.
Good luck.
i had & have Magnecor wires with all current & previous "C280/C43/E55/C43-with 5.4l",,
i don't have any issue with them, they works great..!
ZAYED,,
Try swapping coils and see what happens.
Zayed- thanks for your input. It definitely helps a lot to know the magnecors hold up as well as oem.
Wasp- I'll swap out the coils as soon as I get a chance. Did that clear your check engine light?
One more question, what is the correct gap for the plugs? 7422's come pre-gapped, I just want to double check
No codes, No CEL As soon as I installed Bosch wires all of that went away.
I think Bosch platinum comes pre-gapped? Check in the owners manual just in case.
