M113 cams
M113 cams
Hi, after a lot of research I was not able to get definite answer on what are the best available cams for NA m113 engines? Does anyone know please, I would like to keep my car NA and looking for ways to get more power at higher rpm.
Also, another open question I found is if newer m113 engines found in w209 and w203 amg have different cams and if it's with the change?
2020 E 300 Coupe and 2019 GLS 400
EPC shows (left side) A1130502201 -- must no longer be used -- , replaced by A1130503901, replaced by A1130507901.
(right side) A1130502301 -- must no longer be used --, replaced by A1130503801, replaced by A1130508001.
The part # for the C55/SLK55 are A1130508901 and A1130509001. The w209 has different part #.
Perhaps the best cams are the same ones on the SLK55 Black Series. I don't know if installation is a direct R&R or if it needs modification like the SLR part with the W211.
