transmission 5th gear problem
Old Aug 31, 2016 | 08:09 AM
turbo1k's Avatar
2001 E55 1999 E55 2001 ML55 2017 C43
Yesterday on my drive home i noticed my car wont shift into 5th.
I also noticed it will shift 5th if i do it manually. Im thinking it electrical since it works manually.
Im assuming there must be a switch of some sort but if somebody can point me in the right direction it will be much appreciated Thanks
Steve
Old Aug 31, 2016 | 06:11 PM
turbo1k's Avatar
Actually I was wrong. The car doesn't shift into 5th at all. I have to manually shift it into 4th as it stays in 3rd.
Steve
Old Sep 1, 2016 | 08:01 AM
turbo1k's Avatar
Tried a few different things on the way to work.
If i drive with very light gas pedal pressure it shifts into 5th and stays there until 55-58mph then down shifts.
While driving down the highway i decided to flip the switch to winter mode and instantly it shifts to 5th. I did a few 60mph-120mph pulls with it in winter mode and it works perfect.
Now im 100% sure the transmission in good just need to figure out were the electrical problem is. I changed the electrical connector a few years ago so i might start there. Also i drop my tranny fluid and add 4 quarts every 6months so i know the fluid is perfect.
If anybody know the electrical side of the W/S switch and could point me in the right direction that would be great.
Steve
Old Sep 1, 2016 | 11:56 AM
NAFT1's Avatar
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
Have you tried doing a transmission adaptation reset? It's a long shot, but might be worth a try if it isn't a mechanical problem.
Turn off all accessories, lights, etc.
Insert key and turn to "On" without starting the engine
Press the accelerator pedal to the floor and hold it for 30 seconds.
Leave the key in position 2 for 2 minutes and don't open the door or turn on any accessories.
Old Sep 4, 2016 | 09:44 AM
turbo1k's Avatar
The car no longer has this issue. I had the spare on the left front for a few days while I was having the wheel refinished and after putting the mono block back on all is good.
Steve
Old Sep 4, 2016 | 10:22 AM
cm60k's Avatar
Glad to hear that, Thanks for sharing..
,,ZAYED,,
