Check engine E320 1999 61K Miles
the notches any where in the rear seat to remove the battery, however I found a plastic cover in the rear seat, I pop it off and there is a big ground cable, I disconnect the ground for 10 minutes and now the check engine light goes away, will see if it's coming back.
My wife is drving the car now, I did not notice any below since the check engine like came on,may be too early to tell:
#acceleration is poor and cannot pick up speed like before
#you will hear a popping sound from the area of throttle valve while accelerating at a speed of about 10 to 25 m/h.
#hard starting or engine misfire and shaking.
Been reading thru this forume, look like air mass sensor is the most main root cause for this issue ?
Looking for any advice as much as possible
TIA
