Torque Specs
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
70Nm or 55 lb-ft is the correct torque spec. Just did two of these in the fall. Be prepared, I had to use a 3' extension pipe over my breaker bar handle to crack that hollow 46mm bolt loose. The cooler-filter bolts did not have torque specs that I could find; I snugged them up with a 2.5" driver handle and they did not strip nor does it leak.
