brake light switch
Why does brake light working properly without switch? Is there an ajustment when replacing switch?
Thank you in advance if you think of something else that could cause that.
an aftermarket part could be defective from new if you are unlucky as you don't know the quality of the part?
if you plug it in, and rapidly turn steering wheel left to right a few times ESP/ABS lights should turn off in cluster and you're good to go.
contact sensor from your brake system should touch pinhead on brake light switch triggering brake lights then go off ASAP when brake pedal is released
