e55 amg engine build
Old Jan 2, 2018 | 05:07 PM
Chris Law's Avatar
cls 500
hi all
i purchased a 2001 e55 engine for the internals to put into my cls 500 and when i stripped the mot i found the ring lands on number 5 piston was broke , i read on the forum somewhere that they later went up half a point with the compression ratio to 11 to 1 , would that be the slk 55 pistons and would that account for the extra 10 hp on the slk or was it a combination of parts .
i have a pair of 2005 slk heads with low miles to go on once i build the bottom end , but as im now short of a piston im wondering if its worth looking at installing the newer style pistons .
any advice would be welcome.
chris
Old Jan 3, 2018 | 10:54 AM
takeiteasy's Avatar
05E55-05CL500-02E430
hmmmmmmmm with out readin ur **** the title sound intresting
Old Jan 3, 2018 | 10:58 AM
takeiteasy's Avatar
well my friend i hate to say it but u need sir new JE pistons ARP bolts and make HER GREAT AGAIN THAT WHAT IM DOING.. but besides nitrous im twin turboin her but i need this master from kentucky max hudges to rewire a new ecu everything ells no problem for me ..
Old Jan 3, 2018 | 11:03 AM
takeiteasy's Avatar
just so u know there are about 200 left in us original old e55s dont crash it ... because i totaled my other 1 because of a dip**** that ran red lights .. my friend is gettin the w211 but i just dont like airmatic bull**** i prefer old fashioned coilovers im not talking **** about the w211 but mercedes i think was a bit lazy when they made that car....
Old Jan 3, 2018 | 03:23 PM
Chris Law's Avatar
cls 500
JE pistons require you to install liners into the block , im not for spending that kind of money , id be happy with 400 hp at the crank
Old Jan 3, 2018 | 11:26 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
You can put coil overs on a W211. It's been done many, many times.
Old Jan 4, 2018 | 10:30 AM
NAFT1's Avatar
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
Originally Posted by Chris Law
hi all
chris
In 2004 the CLK55 and C55 received a CR bump to 11:1, and I assume that the internals were left alone for the '05 SLK. I am not sure if that CR increase was through pistons, thinner head gasket, or combustion chamber, but I'd likely chalk it up to pistons. The difference in HP among the three 2005 models was a function of exhaust routing, airbox and tuning. You can easily run these engines for up to 300K miles with proper care and, as you already know, a used bottom end can be had for cheap. A simple tune along with decent headers on any of the 5.4L M113s will net you 400HP. You can nickel plate the bores if you want to run JE or Weistec pistons, but that is still expensive and you loose some of the favorable wear properties of the factory cast-in bores.
Old Jan 4, 2018 | 11:57 AM
Chris Law's Avatar
cls 500
the bottom end was cheap enough but it seems used pistons fetch good money
