SRS light on
Old Sep 7, 2018 | 03:47 PM
sdg003c's Avatar
1999 e55
SRS light on
My SRS light is on and my Indie mechanic, while good, has stated he can not work on the sensor pad in the seat.
Does anyone know of a mechanic in Brooklyn, NY who can work on this issue.
Thank you for your help
Old Sep 7, 2018 | 09:16 PM
AndreNY's Avatar
couple of Benzos
if you want to take it to Ridgewood Queens my cousin owns a Independent Mercedes Shop
Old Sep 9, 2018 | 03:02 PM
sdg003c's Avatar
1999 e55
I have no problem going to queens.
Do you know if he can deal with this issue.
Old Sep 9, 2018 | 06:32 PM
fabbrisd1's Avatar
A gaggle of MB's
Just so you know the "issue" normally boils down to one of two things (1) failure of the seat sensor/pad which requires replacement - involving pulling the bottom seat cover - replacing the pad (2) rarer - a "short" in the wiring/connector on the pad side.
A eBay "emulator" can be used at the connector to eliminate to SRS trigger - in any event I think you will need SDS to reset the SRS light
Old Sep 12, 2018 | 12:30 PM
sdg003c's Avatar
1999 e55
the problem is definitely the pad sensor. I am trying to find a place other than the dealer than can re[place it since my mechanic has told me he can not do it.
Thank you
