Need your help with P017x issues.
To start I did a full Trans service with conductor plate but while I’m sure it didn’t hurt, didn’t solve the issues. Replaced the fuel filter and pump still no change. Broke down and bought a scanner to pull the codes. Amid the Lean Bank codes I also pulled a Mass Air fault, a slow read on O2 sensors, and a TPS fault. Live logged the O2’s and they were well within voltage (9.4v). Unplugged the MAF and car ran a little better but problem remains. I have had to replace the TPS/PPS before and I was considering trying that again. Also between all these steps I am clearing the faults. I’m kinda at a loss here. Hoping someone has had a similar Goblin and can chime in. The MB specific codes I pulled are listed below if that helps the diagnosis at all. Thanks in advance guys and sorry for being long winded.
p2017, p2086, p2080, p200d
It's cheap to do and takes only a moment to do. Purchase a can of CRC MAF cleaner (always handy to have, imo)
Let it dry out before reinstalling and testing again.
Other checks:
1) water contamination in the gas - this will also create this problem you have,
2) you can check your intake system for any air leaks. Simple to do: use/spray a bit of carb cleaner.
If the engine starts to shake or change in idle speed after spraying, you may possibly have a leak on the area you just sprayed.
3) could also be your O2 sensor.
The car has been run almost completely dry several times, especially right before fuel pump/filter replacement. Then filled at several reliable stations. If it was one single tank I’d say completely possible.
The Intake Manifold gasket (or any number of other vacuum lines) are my worst nightmare. This is at the top of the ugh list.
As mentioned both the O2 sensors were spot on at 9.4V. Another fix I was happy to avoid!
Appreciate the continued suggestions sir!
I noticed a hesitation also like a trans slip when accelerating and when I would let off the gas on the freeway, the rpms would fluctuate up and down instead of a steady decline.
Check all breather hoses, breather covers for holes, all vacuum lines into the intake, the one mentioned from underneath, and check for any moisture from around the perimeter of the intake manifold where the seam between upper and lower meet.
If you find a leak in the manifold and opt to DIY, I suggest replacing the intake manifold gaskets below, cleaning the carbon build up inside the intake clean out the EGR, cleaning out the throttle body, replacing that throttle body gasket and definitely cleaning the MAF.
If the hose from underneath is broken or deteriorating, there is not a replacement part for the hose, rather there is a work around which Ill dig up if it turns out to be that. Otherwise you have to replace the entire manifold $$$. Doesn't make sense to get a used one as the hose will be just as weak on an old one.
