E55 w210 oil not measuring
Old Sep 27, 2019 | 09:58 PM
LUNDY's Avatar
Registered User
2007 ML63, 2000 E55
When trying to check the oil level from the dash I get- Oil Not Measuring reading.
Anything I'm missing?
Old Sep 28, 2019 | 02:18 PM
Tall Giraffe's Avatar
2001 E55 OMG
Oil level sensor is on the passenger side top down into the oil pan. From the outside, best you can do is inspect for oil/dirt, disconnect connectors clean with electrical cleaner and hope that solves the problem. If a lot of oil is coming up and out, O ring may be deteriorated. If the sensor is dead or even if its just the o ring, then you have to remove/separate the lower oil pan and there are 2 torx inside that hold the sensor and have to come out before you can remove the sensor up and out. Once done, you have to reseal the pan with approved rtv. Separating the pan is a challenge and be ready as oil will be in the pan and oil will drip down from the upper.
Old Sep 29, 2019 | 11:18 PM
LUNDY's Avatar
Registered User
2007 ML63, 2000 E55
The dipstick reading works fine but the dash is not getting a reading.
Old Sep 30, 2019 | 12:58 AM
2001 E55 OMG
Of course it should, Im speaking of the oil level sensor that is inside the lower oil pan that give a reading to your dash.
