Can we start a picture thread please. Post your 55
Old 10-07-2022, 05:31 PM
  #76
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
Originally Posted by eurochargedw210
The spacers are to clear the upper hall joint, not the calipers. They are not causing a vibration, is it missing the white hub ring?
Yes I agree but I am dealing with spacers and vibrations on my E63s as well especially on the front. I removed the spacers and the car runs fine.
What hub ring are you referring to, any pictures?
I am think about going down to 245 to see if that clears the UBJ
Originally Posted by cm60k
*Front tires are (225/45/19), and wheels (8.5jx19) ET35
*Rear tires (265/40/19), and wheels (9.5jx19) ET42
note: those "C63 507" not set properly at the rear hub, cause "W210" rear hub lip is kinda small offset, which is (13mm),,
for that i used rear hub from "R129", cause "R129" rear hub lip is (15mm)..
-;-ZAYED-;-
Old 03-17-2023, 07:33 AM
  #77
Erno Alanko's Avatar
W210 e55 amg
-;-ZAYED-;-
Few pics from my ride too
kiluminati616 (09-15-2023)
Old 03-18-2023, 10:23 AM
  #78
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Really awesome bride
-;-ZAYED-;-
Old 05-01-2023, 02:37 AM
  #79
EFiddy5's Avatar
W210 E55
First post by a new member
This is my 01. I picked it up last year and have been cleaning her up since.
lowered on e320 spec H&R’s
10mm H&R spacers on the rear only
painted the faded rear hat shelf black
After installing the rear 10mm spacers
No more purple fabric
Personal plates just arrived
The following 2 users liked this post by EFiddy5:
kiluminati616 (05-01-2023), Rotor320 (05-01-2023)
Old 05-01-2023, 08:58 AM
  #80
cm60k's Avatar
Really Gorgeous
-;-ZAYED-;-
Old 05-01-2023, 01:35 PM
  #81
Rotor320's Avatar
2002 E55, 2008 Carerra S, 2012 Cayenne Base, 2017 Panamera S4
Looks great!
How's the ride compared to stock springs? Did you change the shocks or any other suspension components?
Thanks,
DP
Old 05-04-2023, 01:59 AM
  #82
EFiddy5's Avatar
W210 E55
Originally Posted by Rotor320
Looks great!
Thanks,
DP
the Bilsteins we’re replaced a couple of years ago and the ride is decent, not much firmer than stock. The bushings are still in good shape and I had the car aligned after installing the lowering springs. The car handles great at all speeds and feels smaller in corners than it did before lowering it. Next up is a set of stickier tires as the Michelin AS4’s are nearing the wear bars. Any suggestions for good replacement tires?
Old 05-04-2023, 05:40 AM
  #83
turbo1k's Avatar
2001 E55 1999 E55 2001 ML55 2017 C43
General RS are great tires and prices are reasonable.
I run them on 3 of my cars.
mbwillgrubs (05-05-2023)
Old 05-04-2023, 11:17 AM
  #84
Rotor320's Avatar
I use Michelin Pilot Sports. Not reasonably priced, but great tires. I've had some luck with Falken tires in the past on different vehicles. Both of my sons are in the tire business, they only buy Continentals. Tire preferences are likely as varied as those with oil preferences. Mobil 1, Motul or Liqui Moly?
Thanks for the reply and the picture.
DP
Old 07-27-2023, 11:33 AM
  #85
Alpina7's Avatar
2005 Mercedes S600
The following 3 users liked this post by Alpina7:
Bahnstormer (07-27-2023), eurochargedw210 (07-27-2023), kiluminati616 (07-27-2023)
Old 08-18-2023, 10:11 AM
  #86
Bvlet's Avatar
W202 E55 AMG
Did you change the air filter?
Old 08-18-2023, 10:14 AM
  #87
Bvlet's Avatar
W202 E55 AMG
Originally Posted by W205_Merc
you removed the air pump?
I think he also changed the expansion tank cap
Old 08-25-2023, 12:29 PM
  #88
EFiddy5's Avatar
W210 E55
I love these after a fresh wash
sdematt (09-08-2023)
Old 11-15-2023, 07:01 PM
  #89
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
Old 11-15-2023, 08:28 PM
  #90
cm60k's Avatar
Balck always Gorgeous,
soooo nice
(-;-ZAYED-;-)
Quick Reply: Can we start a picture thread please. Post your 55
