Restoring the Headlights
Old May 30, 2021 | 11:53 AM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
After understanding where and what the problem is , watched several videos to see what made sense to me and finally got down to it
Just did one side and the lights came up pretty good, I am pleased with the results.
The brightness/sparkle is definitely back
So what you'll think?
Before:
Before
After with marker light not touched yet
Both lights done
Driver side not done yet
Old May 30, 2021 | 01:35 PM
nw66's Avatar
E63S 4MATIC 213
Yep recently done mine on my 55, well worth doing good job
Old May 30, 2021 | 07:43 PM
MassE55's Avatar
2001 e55 AMG
Such an easy, quick upgrade. Looks good
Old Jun 9, 2021 | 03:29 AM
wyneduke's Avatar
M-Class
Looks great. What restoration kit did you use?
Old Jun 9, 2021 | 09:41 AM
Tall Giraffe's Avatar
2001 E55 OMG
Definitely an improvement. I have used the 3M with great results but it does revert back to yellow-ish usually within a year. The missing step is the sealing to make this last longer otherwise youll be constantly sanding the lens down.
Here is a great one by Youtube channel Paint Society incorporating clear coat
Old Jun 9, 2021 | 10:15 PM
C2 Turbo's Avatar
1)- Clean the headlights
2)- Masked the surrounding area
3)- Using a sanding block and a 600/800 , dry side to side by hand
4)- Turn the headlights on to see if there are any spots that needed further sanding
5)- Sanding again 1500 grit ... wet this time and vertical movements
6)- Lights on to see the progress
8)- Sanding again. 2500/3000 grit... wet and vertical
9)- Light on and if happy with the progress move to next step
10- Alcohol wipes and clean the headlights before moving on to polishing
11)- Using Random orbital buffer, applied Maguire's Ultimatum compound
12)- wiped using alcohol wipe
13)- Finally Maguire's Ultimatum Polish
I have read using a clear coat will cause bit refracting errors and to make it last longer, to use a clear Film like 3M and that's what i plan on ordering
