Help!! Hood latch will not release.
I need help!! My passenger side front hood latch will not release. The cable got loose on the passenger side and now, I can't open the latch on that side. Can someone give me a solution to the problem on how to unhook the latch. The driver's side is fine. I don't understand why MB make two independent latch for the hood. It's definitely over engineered. Who in the world would want to open the hood and steal the engine .LOL.
00 C200 & 00 C55 & 06 SLK55
There's a hole behind the headlight,
you can jack the car, pull out the Engine shield, and use a long plier to catch the cable through that hole..
-;-ZAYED-;-
-;-ZAYED-;-
Do you know a 24" screwdriver will do the trick?
I don't think a set of pliers has the strength to pull from such a long distance from below. Also, I don't think I can reach the cable with pliers from below the car. It's at least 2 ft straight up.
