Hub bore vs wheel bores
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
If I switch wheels from OEM stock monoblocs (66.6 mm) to a different OEM Mercedes wheels (66.6 mm) with both having the same center bores, would I need a hub centric rings, I don't think so? I didn't mention the Hub bore diameter since the new wheels have the same center bores as the OEM stock one's.
