Bore size 66.6 vs 66.56
Old Feb 4, 2023 | 07:54 AM
C2 Turbo's Avatar
1991 964 Turbo, 2002 Black E55, 2002 Black E55 " The Beast"- 2014 E63s
W210 E55 has 66.66 center bore and Mercedes makes wheels with 66.56 center bores too, not sure why?
I absolutely do not want to deal with bloody spacers or hub centric rings and all that crap.
would there any chance of vibration If I was to buy wheels with 66.56 center bore and mount on the car with 66.66 center bore?
Google search says they are interchangeable but I am not sure and do not risk buying wheels that don't fit
If the difference is insignificant, why would this company makes this adapter?
https://usadapters.com/products/5x11...d-1-5-inch-x-2
Old Feb 6, 2023 | 01:47 PM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
From a hub centric adapter manufacture (b2bfab)
Many aftermarket wheels and some OEM wheels require hub centric rings to downsize the center bore correctly center on the hub and to offer vibration free operation.
66.6mm is a common size for lots of 5x112 aftermarket wheels as this is the hub bore of many Audi and Mercedes fitments.
My guess is that the larger bore allows for a greater market range for the wheel. The usaadapter piece seems overly complicated for the task as a bushing might work. Good luck.
Old Feb 7, 2023 | 02:58 AM
cm60k's Avatar
MB wheel & bore sizes should be (66.6mm) & (66.56mm),
cause it must be (0.4mm) gab for proper fitment in the hug lip..
-;-ZAYED-;-
Old Apr 20, 2025 | 06:40 PM
BestiaXpL's Avatar
I recently got wheels for my 14 S63 and the Centers are 66.56mm and they perfectly fit my car
