Battery for W210 E55 - Brand, Ampere?
1 Post
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
My W210 E55's battery is dying
Any recommendation for the aftermarket brand and ampere? Will the size fit perfectly? Should I stick with OEM battery?
Also, I've never opened my back seat where the battery is located. Anyone here knows whether W210 E55 still has a hose for gas / condensation outlet?
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
![](https://mbworld.org/forums/images/ranks/veteran_air_force.png)
Have you seen it? That thing is huge! I hope you can find a suitable aftermarket replacement, but I have a feeling the dealer has the lock on those and you won't find one that fits anywhere else. Good Luck. Let us know the outcome.
1 Post
Really?
I've never seen it..... Three questions for those who can help:
- How to open the back seat? Do I pull the side where the back seat meet the carpet? Or... do I pull the side where the back seat meet the back rest?
- Do you know how much the dealer sells the OEM for? I guess it should be easy to replace, right?
- Any price difference if I have the dealer change it for me vs. I change it myself?
1 Post
4 wheels
Look where the seat meats the carpet on the corner. You will be able to stick your fingers in and pull up on a lever (on both side of the car). It is fairly simple to replace. I would have the dealer do it just to be safe and possibly make sure everything is ok and no fault codes show up with Star Diagnostics.
