Coolant
Old Jun 24, 2024 | 05:35 PM
TwoTone-Gent's Avatar
Veteran: Air Force
2001 E55 AMG
Coolant
Lower radiator hose clamp broke dumping coolant. New clamp, filled reservoir let it run for awhile. Topped it off. Today's 30 min trip resulted in a Check Coolant light. Checked tank, still coolant there. Any thoughts?
Old Jun 25, 2024 | 08:55 AM
mbwillgrubs's Avatar
2013 CL 63, 2002 E 55, 04 Jaguar XJ8, 66 Jaguar XKE
Connector loose or dirty? Stuck float? Good luck.
Old Jun 25, 2024 | 09:03 AM
Veteran: Air Force
2001 E55 AMG
Not sure. Where is the float, in the overflow tank?
I purchased this E55 back in 2015. I have never had an issue with coolant. I also haven't ever seen much in the fill/overflow tank until now. The bottom radiator hose clamp broke and drained the system. I have added 1 and 3/4 gallons at that time. This brought the level in the overflow to reach the top black part in the front. Reading the manual, that is the Ideal position. I have monitored after the first few drives and it has been staying in that area.
Yesterday's round trip was a total of 25-30 miles and near the end is when the check coolant level came on. I checked, no difference in level. I carefully opened the tank cap and allowed some air to escape. Haven't driven it but a few miles since, no more light.
Old Jun 25, 2024 | 10:17 AM
I think so, yes. It might have just burped some air or become un-stuck. It does take some time to get the air out of the systems.
I would keep an eye on it, maybe check before you drive for a few instances.
