18" Lorinser RS90 Wheels
Old Feb 24, 2025 | 10:36 PM
vlaanderen's Avatar
2007 S550
hello all, just wondering what I would have to do to make these fit on my w210 e55
the set is not staggered all four wheels are the same width and offset, i looked on the offset wheel site but that doesn't really tell me much.
thanks
  • 9" x 18" et37
Old Feb 25, 2025 | 12:53 PM
Faast's Avatar
'91 964 Turbo, '02 E55's & '14 E63s-w
thanks
  • 9" x 18" et37
18 x 9 with 37 et will not work, it would touch the top suspension bolt. I had 19 x 9 et 37 with 255/35 but needed 7 mm spacer but then it vibrated like crazy
You could try that set up with very skinny tires like 225 and it could work but I would rather have wider tires
My current set up is custom made with 19 x 9 et 28 (255/35) and 19 x 10 et 40 ( need to confirm - 295/30) and it works out great
Hope that helps
Old Feb 25, 2025 | 01:32 PM
vlaanderen's Avatar
2007 S550
thanks for the info, these wheels came up on FB so i was just wondering, i just bought 275/35/18 and 245/40/18 so I will just stick with my current monoblocks
Old Feb 27, 2025 | 01:36 PM
PJmak's Avatar
Hope that helps
18 and 9 inch is a noticeable difference. He has 18 inch wheels.
18x9 et 37 is only 2mm off from the factory rear monoblock so the rear fitment should be spot on.
The front stock wheel is 31ET and is 8 inches wide so with the wheels above, youll be closer to the inner side of the car which means you might need a spacer.
The higher the offset, the more the wheel wil lbe pulled inwards.
Also, you probably didnt have a hubcentric spacer if you had vibrations. I run a 10mm spacer on my c55 with 19x8.5 ET35 and no issues.
Old Feb 27, 2025 | 01:47 PM
vlaanderen's Avatar
2007 S550
great, thanks for the info
