outside temp sensor in dash cluster
Old Mar 7, 2025 | 12:36 PM
mcamp001's Avatar
2014 ML63 AMG
I'm getting the "Light malfunction" in the display and the only thing I can suspect at this point is the outside temp window on the left side of the dash cluster, which is dark. The rest of the cluster displays are working ok. I searched and found how to remove the cluster (hook or no hook), so that looks pretty easy, but is there a bulb lighting this area on the bottom left? If yes, does anyone know what the spec is? I would rather get the correct one prior to pulling it apart if possible. Thanks!
Old Mar 9, 2025 | 09:56 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
What year is your E55?
