W210 E55 Lowering Lowdown ...
Your stock dampers should work fine with the euro-spec springs as that's the way AMG designed them to originally work
The best way to find out if euro-spec applies to your car is to compare part numbers or by contacting your supplier of choice
Long time no talk man!
You know i'd be all over recommending the "K" but this setup up is not for everyone. And reason i say that is because it's expensive. For anyone who is looking to lower their car on a budget the H&R is your best bet. If you're going all out "K" is is the best setup.
What you been up to lately? Haven't seen you post as much? Still have the beast? Any new mod?
This might be exactly what I'm looking for. I don't want a big drop or a stiffer ride, just an inch or so, and EVERYTHING I've checked out so far has been either too low, too stiff, or (usually) both.
I don't know what spring pads I have installed on my car but the ride hide ends up being 13.75" from wheel center to fender lip on the front (1.25" drop) and 14" from wheel center to fender lip on the rear (1.00 " drop). Kleeman states that their setup should provide 1.25" drop all around but the rear is a little higher creating a slightly rake look which I like.
I understand that the Kleemann is expensive but if you are looking for a great ride / handling combination it can't be beat.
Just wanted to pass along my first hand experience.
You have a Mercedes.. not a Honda.
No doubt.
Alright James, what's the damage (screw the budget) for the whole system (what's included?), and I know your car is lower than I want mine, so what pads are you running?
http://www.evosport.com/product/prod...LM.SUS.M10.SH1
I've been hanging around. But I have split my forum time here and also on the 300C and Magnum forums. I got a Magnum Hemi and the ol lady has a 300C Hemi. No mods on either yet.There is usually not much talk about the our W210 E55 any more. Which I can understand since are much fewer - only sold 500 per year for our model. I still dream about the Kleemann setup - your recommention is all I needed. Glad to see you still have it. I will pull the trigger soon especilly since my 02 factory warranty runs out in 7 months. After that it may be time for a Blower and Brake upgrades. I have number 3 spring pads all around - Let me and Fast55 know which you have. Thanks.
Ttsakai,
I believe your stock pads are #3 which is the highest. I'm using the lowest pad which is # 1. Think i have about 1 finger gap all around or less and looks just right for my taste. You should try going # 1 for a less 4x4 look. Just my 2 cents.
As i've mentioned before running #1 pads all around for the solid track look but street performance. I honestly don't remember how much it cost because i got this a long time ago. Think 00-01. Got it from www.wheelexperts.com Talk to Pete and tell him James sent ya!
You sly dog you!
How come i don't see you on that forum? I'm there too!
Actually i'm everywhere so it doesn't matter. lol
Reason why there's less talk about our W210 is we're special!
Are you kidding me? I'll always have that setup! And once you get it i can definitely tell you it's like buying a 211 E55 engine but with a 210 chassis. This thing is solid! I'm about to finish the engine project soon and will hopefully be over 600 ponies or more if i can. But we'll see. If you have any questions let me know and i'll be more than
to help you out! I read awhile back on an old post that top of the fender-arch heights were 25.75 inches front and 26.1 inches rear with the euro springs and #2 pads. Need to measure my stock height and see what # pads mine came with from the factory.
Ttsakai,
FRONT SPRING PADS
210 321 01 84 5mm
210 321 02 84 9mm
210 321 03 84 13 mm
210 321 04 84 17 mm
210 321 05 84 21 mm
REAR SPRING PADS
210 325 01 84 5 mm
210 325 02 84 9 mm
210 325 03 84 13 mm
210 325 04 84 17 mm
You sly dog you!
yWelcome! But like what you said you'll be starting all over again. If i were you just finish this one. Just my 3 cents.
