Handling Utterly Transformed Via CLS 55 Suspension Parts!
BMW M5, Porsche 911, Mercedes-Benz E55
A well placed contact at AMG in Affalterbach recommended some changes for me when I complained to him about the lack of agility and slow turn-in of my 2005 E55. He said that I should change the parts in two phases. First, he suggested that I change the front shocks to CLS 55 units (i.e. "Hydropneumatic Spring Legs" in Mercedes-Benz jargon), together with CLS 55 lower control arms which contain bushings of a different composition (i.e. "Spring Control Arm" in Mercedes-speak). He was kind enough to send me a prototype set of these lower control arms. Apparently, the latest bushing configuration will not make their way until June 2005, when the revised bushings will be included as a running production change.
The technical types at MBUSA repeatedly warned me that the CLS 55 front shocks simply won't work as a retrofit to an E55. However, my friend at Affalterbach told me this was nonsense. In fact, he told me that when they were developing the CLS 55, they had an E55 test mule fitted with these same CLS 55 front shocks and updated (i.e. faster) steering rack.
He said that if retrofitting the CLS 55 lower control arms and front shocks didn't satisfy, I should then retrofit the 2005 E 55/CLS 55 steering rack (i.e. it's 14.8:1 ratio is a bit quicker than the 15.3:1 ratio found on the 2003-2004 W211 family). The only thing he warned me about was that this steering rack could slightly throw off/confuse the map on the "ESP Speed Sensitive Power Steering Control Unit." This could only be a problem on the tightest roads when suddenly/abruptly applying full power.
So far, I haven't had time to install the steering box. I can categorically state that with only the lower control arm and front shock update, the handling of the car has been utterly transformed! The front of the car is much tighter and stiffer, but not uncomfortably stiff. The steering response/precision/turn-in is much more responsive, sharp and immediate. Simply stated, the car feels far more agile, light, and sure-footed with quicker reflexes.
For those of you who plan to do this, here are the correct Part Numbers (which were obtained after much research). The Mercedes-Benz database is a bit confusing/contradictory about the correct part numbers for the front shocks. In fact, my dealer phoned a technical higher-up in New Jersey just to confirm the correct part number. Had I not verified the information myself with my contact in Affalterbach, I would have ended up with CLS 500 front shocks!!! Once I opened the boxes containing the CLS 55 front shocks, I was sure that I had the correct shocks (i.e. each of these new CLS 55 shocks has bright yellow AMG stickers).
Left Front Shock: A211 320 83 13
Right Front Shock: A211 320 84 13
They retail for $1,100 each.
The Steering Rack ("Steering Box Assembly" in Mercedes-speak) is A219 460 10 00. It retails for $2,840.
The CURRENT Part No. for the CLS 55 lower control arms are:
A211 330 81 07 (Bottom Left)
A211 330 82 07 (Bottom Right)
They retail for $281.60 each. Once the running production change for the bushing compound occurs this June, it might be possible that these Part Numbers might change?
I was charged 11.3 hours labor for the installation of the shocks and lower control arms (including an alignment). The further labor for the steering rack change will be 4.6 hours. However, I'm not sure whether this figure includes the 1.7 hours that books says an alignment takes. I'm also not sure whether a steering box change requires a further alignment.
All I can see that even though I haven't yet done the steering rack change, the car has been transformed. It feels much, much lighter on its feet. This is something that is quite noticeable in day-to-day driving, even when not pushing the car in cornering situations. When cornering hard, the difference in steering feel, steering response, and overall confidence is night and day! The car simply now invites the driver to push it at every opportunity. In a word, the car now feels far, far sportier!
prototype?
I am confused as to which control arm you recieved. you said that in one case it was a prototype and then you give the part number of the current control arms. You do mention that starting in june there is a possiblity of there being different part numbers and I wondered if the parts you received are the current ones or a prototype.
What you had done sounds great, but I would obviously like to make sure that the "current" control arms are the same as the prototype. thanks.
Originally Posted by thearle
Anything done to the "softer" rear? How is the car's balance?
The Part Nos. I provided are for the lower control arms containing the CURRENT version bushings. However, since these bushings will be a "running production change" beginning in June, it's likely that the Part Nos. WILL NOT change. Therefore, it might be wise to simply wait until June-July to order the lower control arms.
SL 65 AMG and E63s AMG
I'm not sure about the handling of the CLS. Although I noticed quicker turn in and slightly stiffer ride I found it to more tail happy than the E55. I know that understeer is prevalent with the E55 but I felt that it was more controllable than the CLS at the limit. It might be that I'm just used to the E55 more than the CLS but I never got close to swapping ends with the E55. I did it twice on the low speed hairpins recently.
Have you checked you lateral Gs since your change out? The CLS55 supposed to have a .91g. I don't believe the claim that E55 has a .83 lateral g rating. That is what they claimed about the E320 when it was introduced. It should be better than that.
prototype
thanks. It seems better to wait until the line production is stable. Finding a cls 55 to drive is basically impossible down here in new orleans. it is alot to pay for two shocks and a bit more, but I guess i'd do it.
2005 E 55 Amg
Why did you buy the 2005 steering rack when you already have a 2005. Did the new steering rack come with the updated center console in 05.
The (2005) updated center console has nothing to do with the steering rack.
2005 E 55 Amg
My car is Model Year 2004. The (2005) updated center console has nothing to do with the steering rack.
Oh! I thought the center console allowed faster turn in
I just assumed they made all these changes at the same time for the 05 incuding the faster steering rack.
The thing that I've most noticed about the car since changing the front shocks and lower control arms is its willingness to tighten its line even once the car has already "taken a set" in a constant radius turn. Unlike before, it's now possible to crank in additional steering lock/imput mid-corner.
Originally Posted by Frank Wiesmann
Does your contact know if and when these CLS 55 components will find their way into the E55s leaving the factory?
Bumping this because I have a few questions and a lot of the threads/posts are years old at this point. I would love better steering response, not sure if its worth the hassle though.
I'm sitting at 160k, the car pulls slightly to the right and I was planning on going to MB for alignment. All front control arms/ball joints are new, except for the tie rods, so it makes sense to do those prior to alignment.
1) I have an 03, so the 'old' rack, should I pull the trigger and just get the upgraded rack and call it a day?
According to this they aren't that expensive ($400): https://www.mboemparts.com/oem-parts...r-219460100080
There are used ones all over Ebay for half that, but I'd want to buy new inner and outer rods and it appears the unit from MB comes with those already, so it's actually cheaper through them. I'm hoping they don't deny core reimbursement if I'm sending back an older rack..
2) Is this concern about ESP problems legit? I've only seen it referenced once, and only as a theoretical. I drive my car fairly hard, but I'm not pretending it's a C63 and I don't track it, so I doubt I'd meet the threshold of moving the wheel too quickly under power.
