Anyone have ongoing issue with SRS lights stuck on?
E 63S Wagon Renntech, E55 Renntech, SL65, SL 55 030, ML, bunch of old ones--they come, they go...
05 E55 with no other problems, about 10k miles, but SRS light absolutely will not go off. Dealer has had several attempts, and made valiant effort. Last thought was a new wiring harness. Thought that was going to do the trick. Didn't. Anyone else have this problem? I'm going to post it over the regular E board too. Thanks.
You've got to be kidding me....
no one else here has this problem? THe MB tech rep told me that they were aware of 4-5 in the South FL area alone. Maybe you had it and fixed it? Code shows a fault in the driver's airbag, although that's been replaced and ain't the problem. Neither is the pinched wire thing in the steering column, nor the the wiring harness, not the seat belt latches. Help!
