New E55 Ordered, Questions
1. why does a S/C motor have more torque than corresponding HP figures like a normally aspirated motor? Is MB lowballing the hp numbers?
2. How many 2005 E55's are there for sale in the U.S.?
3. I would like to mod mine with an entry level kit, like pulley change, ECU remap, etc. What does everyone think is the most "bang for the buck"?
4. Is there an AMG owners club in southern Michigan around Ann Arbor/ Western Detroit?
Thanks for reading this wordy post!
For example, a 1990 Corvette with a 5.7 L V8 made 245 HP and 330 lb-ft with no blower. The peak power was achieved at around 4000 rpm. The motor. with its small valves and ports couldn't flow much air above that point, and it ran out of breath by 5000 rpm.
The DOHC ZR-1 Corvette from the same year made 375 HP and 370 ft lbs of torque, from the same 5.7 liters, but the power peak was at about 5400 rpm. The same motor, when modified with ported heads/intake, etc can make 500 HP at 7000 rpm, but torque will be in the 400-420 lb-ft range. It's the 7000 rpm peak (well above 5252 rpm) that inflates the HP number.
HP= Torque x rpm/5252....basically, HP = torque over time. So a higher revving peaky motor makes more torque at higher revs, ie high horsepower, but low end torque is lacking.
Supercharged motors (at least the positive displacement ones like in the AMG cars, Jaguars, Fords, Pontiacs, etc) have high volumetric efficiency at low RPM, hence the low end torque, and lower power peak. Aftermarket centrifugal superchargers do not follow this rule, because they don't have the copious boost at 2000 rpm that the AMG's lysholm blower does.
Hope that helps a bit....
docV8: very informative, thank you!
