1st time to the drags...vid!
1 Post
04E55AMG, 05Dodge RAM 1500 Quad Cab, 02Montero Limited
Originally Posted by Peter B
dont sweat it dude, it was all in good fun. glad you could join us. it was my first time too.
and dje55 10 of us had the track for about 6 hours. it cost $104 a piece. gotta make it out next time.
and derek, how does rt NOT effect et? i dont understand.
Hey Man,
Was talking to Rick at the track and he said if we ever showed up on a Friday night and showed the crowd how we run in the 11's the whole place would go "Hog Wild"
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
07 S65
Peter, the timing clocks don't start until the car leaves the line. So you could sit there forever and your time down the track wouldn't be effected. I made a trip with my car up to 75 & 80 Dragway (between Gaithersburg and Frederick) last Friday night. The Friday night crowds are different. I had people almost laughing at me when the car was in the staging lane. After I made a pass I had mutiple people coming up to the car and taking a picture of the car. They couldn't believe a MB ran that fast stock. My car isn't running the times your cars are so I know they would freak out if they saw one in the 11's. If you guys want to go on a Friday night, let me know. Like I said, I'm pissed that I missed out on this one.
Derrick
Derrick
Originally Posted by 04E55 AMG
Chris it was greating meeting you yesterday and your Cobra looked awesome. Jason had mentioned to me that your car was pushing 600HP (not rear wheel) so I am sorry if I was wrong. With your trap speeds, I can not imagine that car not getting into the 11's.
on another note, it was great running with you guys. if we do another one, i'm definitely down as long as my schedule works out.
jason
Originally Posted by DJe55
I had people almost laughing at me when the car was in the staging lane. After I made a pass I had mutiple people coming up to the car and taking a picture of the car. They couldn't believe a MB ran that fast stock. Derrick
'07 Porsche 997TT
No LSD yet. Agree it is all about the driver and I still need lots more practice. Both cars were running neck and neck most of the day (EVO & K2) with the K2 having a slightly higger trap speed every run. I assume that means that the K2 was putting more HP & Torque on the pavement for it to be moving our 4300 pound sedan faster in that distance. I may be wrong but it seems logical. (It would make sense since I have my primary cats removed and Mike has his still on).
Sam your stock car was running strong and Chris from NY with his Renntech ECU/Pulley bested at 12.02. Jason with his C32 (Renntech ECU/Pulley) ran a 12.5 (Awesome Run).
Paul with his new 2005 E55 (800 miles) had never been at the track was getting into the 12.4 area.
Our CL55 was running 12.2's all day and it was the heavier of the cars.
It is great meeting local "nuts" and having fun with our family cars
BTW - Rick and Kim enjoyed our group and we have a open invite whenever we want.
Most of us had our suspension set to "C" mode with traction on and "S" mode for the transmission.
Thanks everyone for the great turn out and next time we will try and get a dedicated person to video complete runs.
#33
'07 Porsche 997TT
Originally Posted by DerekFSU
What was your dyno before your mods?
#34
1 Post
http://imageevent.com/kompressor/dra...bh1ff3.zebra_s
met some good fellas there and had a great time. made 18 runs!!! hit a bird decelerating for 119.....poof!!!....there goes my middle lower mesh grill. easily took off 1/2 my tread but it was well worth it. on the run in the vid (camera vid doesnt zoom so only get 1/2 run) was my best of the day. .735 rt, 1.886, 60 and 11.81 1/4. evo stage 2, big ol honkin 19's with pole positions no lsd. CRUSHED!!! i mean CRUSHED my pal spero with his kleeman k2.
I think that last run that I ran the 11.93 with my front tire going flat during the run(only had 13 psi) when I turned off the track could of been a 11.8 or under. When I compare my 60 time of 1.815 to your 1.886 and I was always traping higher then you all day that would of translated into a kick-*** time.
Figures by best 60' time and I get a flat tire. I tried calling you earlier today when I was washing the car from all that brake dust. How is your front grille?
Greek
#36
1 Post
Next time inflate your front tires up to around 45 psi. Makes for less resistance going down the track.
#37
Thanks for the tip. I had normal street pressure in all tires.
#38
1 Post
R U running DR's? Run the Dr's around 17 psi. If you do not have DR's, go get some. You cannot fully appreciate what you have from Kleemann without better traction. Even the PS2's do not do it justice.
#40
1 Post
With DR's, a good burnout in dyno mode, and a decent launch- you should reduce your time by a good 2-3 tenths of a second.
Once my LSD arrives that should also help. What DR's and size should I put on my stock 18" rears?
If you make it up to MD you can go to the track that we just went to.
#41
Greek
Greek
![mercy](https://mbworld.org/forums/images/smilies/mecry.gif)
#42
1 Post
I have been waiting on the OEM AMG LSD for the last 6 months. Let me know what type of DR's you get for the stock rims since I will do the same. We should see a big improvement
Mike has a great operation and does great work. He installed Alex's headers and did my lowering mod. He is talking about the high flow cats and Y-pipe that he did on his car for your exhaust.
My next two mods will be LSD & cooling
#43
07 S65
#45
Are you running your dr's that low? I had them before and never let them down that low. With the dr's soft sidewall I thought you would get them to buckle in the middle with that little presure. Check your tire tracks and let me know. Not second guessing you (you're da man), just curious what you guys are doing.
#46
1 Post
Alright guys, who is Mike? I need some guys in our area that can work on our cars. Give me some details please. Thanks
Derrick
Derrick
Derrick,
Mike owns Altered Atmosphere Motorsports in Gaithersburg. He specializes in performance tuning & custom installations. He owns a 2004 E55 so he is very familiar with our cars.
www.alteredatmosphere.com
8011 Cessna Avenue
Gaithersburg, MD 20879
Mike Mahaffey - 301.33.8835
BTW - Look under customer cars on his site and you will see my beast.
#47
07 S65
I know those guys. I bought a shifter from them for my M3. Also, I have my Mustang dynoed right behind those guys at Maryland Performance. I will have to give him a call and see what he can do for me. Thanks!
Derrick
Derrick
#48
2005 Brilliant Silver E55
Spero, crazy at the office...will call you this week.
Chris, I don't think trapping at 114 is necessarily bad, that just tells me you car got out of hole real well. If memory serves me right the ET was something like 1.71 or so which is like super awesome. My car's best ET was 1.87 and I ran a 12.2 @ 115. Kleeman did state to me that my ECU needed retuning since they needed to change the timing on it due to the headers (duh on my part) I should see an increase...actually all this doesn't matter, I'm going to sell my car this week. Don't know what I'm getting yet. I was thinking of the SL600 and add SL65 rear Diff, and Renntech tunning. That car should be pretty strong then.
Spero, yeah man I think I'm gonna sell the CL...wish I could take out the LSD in an inexpensive way but unfortunately it isn't. I told Ustino to give me at least $90K for the car so we'll see...$85K was a bit like a kick in the *****.
BTW, it was nice meeting everyone. Jason, I swear if you ran 2 more times you can get your car into the 12.6. Your car seemed to get faster and faster.
Oh, I have not washed my car yet since the track...all this rubber stuck on the rear bumper....hehhee.
#49
I'm guessing E55 power is Alex. You seem to switch cars every couple of months, u must be PAID!
Anyway, An SL600 with SL65 diff and renntech goodies would be SICK! Can't wait to see that. And by the way, Jason did run a 12.5 on his last run. His intake hoses had fallen off and thats why he was slower at the beginning of the day. Once we put it back on he was running strong. I think a couple more passes and he would've broke 12.5!
#50
2003 E55 & 2014 GL550
Yo Bro,
I was thhhiiisss close to having Kleemann install an SL 65 LSD rear in my beast....we decided to scrap it when they had to order new half shafts for it and it would have taken more time.....if you have the $$$$$$ call Klee....they can hook you up. Gonna cost though. They were cutting me a deal if you can believe it for 4500$ for the rear alone...no labor and no half shaft included in that. Benz.....you sure pay to play.
Maybe give Cory a call and see if they got rid of it yet??
