Dynamic Seats on 04 W211
Ive got the dynamic seats on my beast, and the driver one is always on.. I turn it on once and stays even if I turn the car of and then on, but in the front passanger seat which also has this same system- you have to turn the dynamic mode on under your seat everytime yo go for a ride, so do you know a way to make the passanger one as the drivers, I mean that it can keep on?
Thanks.. Greetings from Chile!
, was to put all the passenger seat settings the way you want them (including the dynamic seats turned on) and then set it in the memory 1,2, or 3 location. Then you should just need to press the correct memory location number once and it will have the seat in dynamic mode turned on.Hope that helps.
