Best brake upgrade for W211 E55 sedan?
#51
2017 S63 Coupe Iridium Silver
Originally Posted by Mr. Vanos
There was nothing premature or misleading about the post. The rotors are available as DRILLED or SLOTTED, depending on your preference. This customer just preferred drilled to maintain a more stock look. This is an E55, not a race car.
E55 is what you make it. If it's not "a race car" why do all the enthusiasts here keep taking it to the track...? Surely it's meant to do more than 1/4 mile in a staight line?
Anyway, evosport should be congratulated for their efforts. If the new rotors perform half as well as they look, we will all be very happy. The fact that they offer a 34lbs unsprung weight reduction compared to the stock rotors is a good start! The same 34 lbs of heat sink could work either way: quicker to heat up but also quicker to cool down.
#52
Evosport upgrade
Mr. Vanos, that looks very promising! Correct me if I'm wrong, but the Evosport rotors look bigger than the stock rotors. Would you recommend slotted or drilled rotors for street and occasional track use? A road/track test update on your part would be most appreciated. Thanks.
#53
Interested!!
I email evosport already and waitng for the reply.
I hope this new brake will take away the squeaking noise that coming from the OEM Brake.
Will the Kit come with the Pad too or just use the factory pad?
So my final question is drill or not drill on the new Direct Replacement Rotors? I want BEST performance...so if the above discussion is right, lighter performance better, will drill rotors a better choice because it will be lighter after drilling the holes? may be a dumb question but pls forgive me to ask. thanks.
#54
Received 1,085 Likes
E55, GLS450, GL63, GLE350
Drilling holes actually decreases your surface area and decreases your brakes ability to absorb heat before loosing their effectiveness. The best rotor for the track is a slotted rotor that are properly vented with air to keep them cool. The holes in drilled rotors are stress risers that lead to cracks after repeated hard braking. Drilled rotors have a very good "bling" factor but serve little purpose now that brake pad technology has evolved into pads that do not outgas.
#55
The only "drilled" rotors that are somewhat resistant to fractures are the ones that are "cast-drilled" such as the 993TT. Drilling and slotting both also prevent the ability to "turn" the rotor in case of some grooving or warping. The rotor has to have enough mass and cooling to prevent heat from cooking the pads and calipers and brake fluid.
#56
You can resurface drilled or slotted rotors:
http://www.carquest.com/techbulletin...%20rotors'
#57
211 E55(sold) & 80cc shifter kart
LOLOLOLOLOLOL J/K
#58
g
Originally Posted by BMWEATR
YES IT IS A RACE CAR DAMN IT!! DON'T YOU TELL US WHAT IT IS AND AINT! WERE ALL RACE CAR DRIVERS MAN! SO GET THOSE DAMN ROTORS READY CAUSE WERE GOING TO THE RACES THIS WEEKEND!
AND FRIGN SCHUMACHER BETTER GET OUTA MY WAY WHEN I DRAFT BUY HIM AT INDY!
LOLOLOLOLOLOL J/K
LOLOLOLOLOLOL J/K
#59
LOLOLOLOLOLOL J/K
LOLOLOLOLOLOL J/K
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#60
Originally Posted by NOTKTS
Lmao, it seems some one has had a little to much free time at work lately :p
#61
[ROFL]
#62
LOLOLOLOLOLOL J/K
LOLOLOLOLOLOL J/K
lololool
#63
MBWorld Founder
One more important thing worth mentioning here...the stock discs do NOT have a unique right and left part. This means there will be one side (I believe the right side) where the vanes of the disc are backwards hence working against optimal brake venting. The new discs offer a left and right so that the vanes are pointing the correct direction for venting.
#65
Originally Posted by norb
If you're still on stock Conti's the better upgrade would be to Michelin PS2's instead of brakes.
oh ya it wont... it will just make it worse.....
#67
Will the slots on the new discs alo follow the directional L/R pattern?
#68
#69
MBWorld Founder
#71
lets talk brakes and you talk about tires...
krispy likely was scared off by you but me... im far more resilient than that![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
PSII's are great and i agree they make the car more enjoyable but they sure wont make the brakes fade any less.
see this is where the rift exists. some of us drive the car hard and only those who do drive the car hard will see that the brakes leave much to be desired. it might stop well once from 140 but try that 20 times in a row during a 30 minute lapping session. bye bye brake pedal.
![tard](https://mbworld.org/forums/images/smilies/tard.gif)
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
