Newbie with E55 wheels questions
00 ML55 and 00 E55
I owned a 2000 E55 and just purchased a set of 2005 E55 wheels and tires on ebay. The seller guarantee that it will be a direct bolt on without a problem. I've since found out from reading this forum that the lugbolts size is different (12mm vs 14mm). I also ordered a 14mm ball seat with 12mm thread logbolt from Pure-Motorsport to make sure it will fit properly. my question is, will the 2005 AMG double spoke fit my car with enough clearance of the caliper or does it require a spacer.
thanks for your help.
Nopie
Nopie
The W211 has bigger brakes so their should be enough clearance. Here are the specs for the wheels:
W210 E55
18X8.0 et31 front
18X9.0 et35 rear
W211 E55
18X8.0 et30 front
18X9.0 et39 rear
The new front rims will go outward 1mm.
The new rear rims will go inward 4mm.
W210 E55
18X8.0 et31 front
18X9.0 et35 rear
W211 E55
18X8.0 et30 front
18X9.0 et39 rear
00 ML55 and 00 E55
Thanks E55 Kev
I notice you guys are in Northern VA. I work in Reston, VA and live in Leesburg, VA. Can you guy recommend a shop that can lower my car for a resonable price?
thanks..Nopie
thanks..Nopie
Originally Posted by E55JAY
Hey Kev...I havent seen you on the boards in a while, you and I have been here for some time huh?
thanks..Nopie
thanks..Nopie
CDE Motorsport 703 560-5669
also:
www.autothority.com in Fairfax
or
Eurospeed Motorsport - 301 333-4882 in MD
