HELP: Malfunctioing ABS, ESP, Brake lights?
Old Aug 21, 2005 | 04:44 PM
teflon's Avatar
Hi all...Need a little advice on this one: On my '99 W210 E55, I was removing my K40 radar detection system. To get it all out, I had to remove the fuse panel under the hood, including the assembly with the "big blocks" (I assume they're fuses or relays) near the back, to get at the wiring underneath by the "foam". I'm pretty darn sure all the fuses are seated properly. When I start the car, all is good. Hit the brake pedal, and ABS, ESP, BAS "Defective Light" all light up on the display. The car seems to drive fine, but the brake lights seem to be out, and of course, the warnings on the display stay up.
I'm not sure if my messing around under the hood disturbed something, or if this is completely unrelated, but any advice would be welcomed. Thanks in advance!
