Keyless Go Problem....
Old Sep 3, 2005 | 01:34 PM
neosky's Avatar
2012 MB CLS63, 2012 Le Man Red SLS
Hi,
I have a 2005 E55 and lately my keyless go system is experiencing the problem of not being able to detect my key in or outside the car. I can't lock or unlock the car using the car handles anymore and I can't start the car either because it keeps on saying "key not detected." However, I can still be able to lock or unlock, start or shut off the car using the conventional key. I have noticed that my key is also having a hard time trying to lock or unlock the car from some angles (it never had any problems before).
Has anybody experienced this before? Is it because it has low battery, which would seem strange because I only had the car a little bit less than a year.
Help!
Neosky
Old Sep 3, 2005 | 01:36 PM
MB Fanatic's Avatar
4 wheels
Sounds like a bad battery in you key fob. Go to your local Radio Shack or something and get the batteries replaced with some other Li-Ion batteries. Should take care of it.
Old Sep 3, 2005 | 06:41 PM
WBRCobra's Avatar
Keyless Go
I put new batteries in my fob when I bought the car in July and I'm still experiencing the same problem. Not all of the time, BUT on a fairly regular basis. I plan to have MB service look at it next time I take the car in.
Old Sep 4, 2005 | 01:00 AM
RezF's Avatar
Is is happening in the same area? Is the area polluted with alot of radio frequency interferences? If the problem is not regularly ocurring then it is unlikely that it is a battery problem or transmission probem from the key card. You should try to rule out outside sources of interferences, first!
Old Sep 4, 2005 | 10:17 PM
neosky's Avatar
It turns out my batteries in my key was low!
Phew......thought it was another typical Mercedes quality issue.....got me scared! LOL!
Old Sep 5, 2005 | 02:50 AM
MB Fanatic's Avatar
4 wheels
You will be surprised how fast Keyless GO can eat the batteries in the fob. Just a small drawback to an otherwise awesome system.
Old Oct 3, 2007 | 05:29 PM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
So how do you open the fob to replace the battery ...
Old Oct 3, 2007 | 05:36 PM
stevebez's Avatar
Old Oct 3, 2007 | 06:41 PM
waxking1's Avatar
CL65
I just changed the batteries in my key. It was working fine, but a message came up telling me my key battery was low.
Old Oct 3, 2007 | 07:36 PM
NGS_E55's Avatar
2013 CLS63 2004 S55
to change battery...
take out valet key, should see a gray release switch on the inside. push the release switch with the valet key and simultaneously pull the top half of the fob, exposing the battery.
Old Oct 3, 2007 | 08:40 PM
Torquey55's Avatar
2006 E55
I was getting the same message. Freakin' dealer wanted $23 to replace the batteries in my fob .
I spent less than 6 bucks at WalMart & cracked open the owner's manual for the battery replacement instructions. Took me 30 seconds to replace them.
Old Oct 4, 2007 | 04:04 AM
stevebez's Avatar
I thought men never read the instruction book ... ?
Thanks for the help.
Old Oct 4, 2007 | 06:05 AM
Zod's Avatar
Zod
CLS55 2006, CLS 63S 2015
No man reads instructions!!! they were not designed for anything other then women mocking men for not reading them!!
and if you look closely ( with feminine and instruction reading eyes) you will find that each instruction manual comes with the phrase ''I told you so, you should always read the manual!...men! ''
no offense was intended with the post and we would all be lost if not for that phrase
Old Jun 20, 2008 | 03:56 PM
m3j0n's Avatar
W220 V12TT Land Yacht / W211 E55 Estate
yep, every 6-8 months for me....
Old Jun 20, 2008 | 07:21 PM
m52e55's Avatar
'11/E63-Former car: '05 RT4 E55, Sprintbooster, Phenolic Spacers, RT IC /Secondary HE & BMC Filters
keyless go here. sounds like battery, as mentioned.
Old Jun 20, 2008 | 07:34 PM
W211 BEAST's Avatar
2006 E55 BEAST
Dealership replaced the battery in my key for free (Downtown LA Motors)
Old Jun 20, 2008 | 08:30 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
Open the battery storage.... take out one battery.... bend the metal piece that's touching the battery to touch the battery even more. It should fix the problem... at least mine
Old Jun 20, 2008 | 09:17 PM
sack5000's Avatar
2015 AMG C63 S
Oh well
We are responding to a thread that is almost three years old! Batteries should last so long.
Old Jun 22, 2008 | 10:18 AM
JokerzWld's Avatar
2014 GL 350 on order
Drivers: just read my horror story re; key fob failure! Joker
