Battery weight
Old Sep 15, 2005 | 11:51 PM
E552006's Avatar
2020 G550
Battery weight
Has anyone tried a smaller, lighter, battery for the E55.
Any effect on the factory electronic etc...
Old Sep 16, 2005 | 10:40 PM
e55 baller's Avatar
W221 S65 AMG
picking up a 12 pounder tomororw from the Battery mart in VA. I had this on my S4....NO problems EXCEPT if you do not driven the car for 7-10 days it will die....so get a battery charger for long periods of inactivity.
Should reduce the weight by about 40lbs. Which is a good thing, but it is over the wheels so perhaps an adverse effect on grip?
Will let you know my experience asap.
this is what i had on my S4 and it worked! no problems. Wonder if this will be able to start the crank on our V8 motors?
Quantity in Cart:none
Code: SBS-J16
Price: $109.95
Shipping Weight: 15.00 pounds
Optional SAE Terminals $12.95
http://www.batterymart.com/battery.mv?p=SBS-J16
Quantity:
Specs:
Length 7 in.
Width 3 1/16 in.
Height 6 5/8 in.
Drycell Battery
12 Volt
16 Ah @ 10hr rate
280 CCA
680 Cranking Amps for 5 Seconds
28 Minute Reserve Capacity
Cycle life @ 77°F 400 at 100% DOD
-40°F to 140°F Temperature Range
1.75Vpc/77°F
Float Voltage 2.27 Vpc @ 77°F
FAA-PMA Approved (non FAA approved version)
Part number: 0769-4005
SN: 3094W0444
Installation Eligibility Model: Piper PA-18 and PA-19 series
More Specs: (Adobe PDF)
Old Sep 16, 2005 | 10:54 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
I'm not sure having that lead weight sitting on top of the right rear tire is such a bad thing. Remember the times the E55 Wagon had? If you don't have a LSD it might be an advantage.
Old Sep 16, 2005 | 11:55 PM
e55 baller's Avatar
W221 S65 AMG
Yeah the E55 wagon went 12.1@113.8 in the mags....
I have the LSD but frankly I can't tell it does much...car still spins spins spins and thats on PS2s
Old Sep 17, 2005 | 12:27 AM
E552006's Avatar
2020 G550
Code: SBS-J16
Price: $109.95
Quantity:
Specs:
Length 7 in.
Width 3 1/16 in.
Height 6 5/8 in.
Drycell Battery
12 Volt
16 Ah @ 10hr rate
280 CCA
1.75Vpc/77°F
SN: 3094W0444
Sweet!!
Let me know your results...
We are from the same stable.. I have had 3 MKIV TT and an RX7 myself.
We love less weight.
Just need to reduce mass in front to make weight transfer more efficient.
Old Sep 17, 2005 | 10:36 AM
E552006's Avatar
2020 G550
Just looked at the terminals of that battery in the pick.
How do you hook it up?
