Fuel & Performance
Old Nov 18, 2005 | 05:07 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
Fuel & Performance
Well there was a program here on telly in UK recently about the difference between fuels. Something that would certanly be of interest to us with Forced induction motors ... so here goes ...
Cars:
Renault Clio
Golf GTI (new turbo)
Impreza WRX STI
Fuels:
Normal Unleaded (95 RON)
BP Ultimate Unleaded (97 RON)
Shell Optimax (98 RON)
Mearuring BHP figures on a chassis dynamometer (bolted to the 2 or 4 driven hubs) they found the following....
Renault Clio - gave the same bhp on all 3 fuels (82bhp IIRC)
Golf GTI - Shell gave 5bhp more than UL, BP gave 2bhp more than UL.
WRX STI - Shell gave 15bhp more than UL, BP gave 8bhp more than UL.
Finally they tested the torque figures of the WRX. Shell was 15 Nm(IIRC) ahead of BP, which was a minor increase over normal.
So 98 RON vs 95 RON gave 15bhp difference which in the case of the Subaru worked out to around ~7% increase. What surprised me was the increase in torque which was up around 10% - pretty much across the entire curve (98 vs 95 RON).
Rule of thumb (as if you did not know it) : Put the highest octane you can source in your E55! 7% on 470 bhp is quite a few hp!!!
P.S. for UK drivers Tesco recently launched 99 RON - apparently as good if not better than Optimax but around 10p/litre cheaper!
Rgds Steve.
Old Nov 18, 2005 | 10:36 AM
Cormac's Avatar
S65 V12 Bi-turbo
Interesting post. Makes me wonder who is partial to what fuel and why? I usually just fill up at whatever gas station I come by, but then again, I'm not driving a E55... yet
Old Nov 18, 2005 | 05:20 PM
OzE55's Avatar
2003 E55
Correct me if i'm wrong, but 'power' is calculated and 'torque' measured on the dyno, so you expect the increase in both to be much the same.
Old Nov 18, 2005 | 05:38 PM
E55AMG99's Avatar
1951 Caterpiller D6
All that is saying is the octane requirement of the Renalt is at or below 95RON and the other two cars are at or above 98RON. You can figure out what is right for your car by filling up a few tanks with a one octane rating and measuring the fuel mileage. Keep doing that for each different octane rating until your mileage reaches its highest. This isn't 100% accurate but very close.
Old Nov 19, 2005 | 12:15 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
I think it makes more of a difference with a turbo car since many of them will allow the boost to go a little higher with higher octane since it takes longer for knock to occur. I don't think on a supercharged car the computer has many options other than timing. Would be interesting to find out though...
Old Nov 19, 2005 | 03:47 PM
stevebez's Avatar
Yes power is the rate of torque delivery ... but what surprised me was an increased torque even low in the rev range... I would have thought the fuel would have most benefits at top end.
On cars where ECU have ability to remap timing to adjust for knocking is where a higher octane fuel helps - timing can be run very advanced without knocking.
Rgds Steve.
Old Nov 19, 2005 | 05:44 PM
E55AMG99's Avatar
1951 Caterpiller D6
You have your events in the wrong order. The ECU responds to detonation, ping, knock, etc. by retarding timing and/or lowering boost in cars with controlled wastegates/blowoff valves. It does not "see" higher octane fuel and raise the boost, etc. Also, higher octane fuel does not take longer for knock to occur. The engine will either knock or it won't.
Old Nov 19, 2005 | 05:45 PM
E55AMG99's Avatar
1951 Caterpiller D6
Rgds Steve.
Low to mid RPM is a place where knock occurs often. Usually right around the torque peak. The load on the engine is very high if not the highest there.
