Need Part numbers on 211 E55 engine mounts
Just as the thread title suggests... I called Kleeman and was told by the sales guy that I should try using the E55k engine mounts in place of the ML55 mounts. The ML55's engine mount were an inferior design(go figure) which barely could hold there power load. Any owner who drives spiritedly goes through mounts on a regular basis. The E55K motor mount is designed to absorb the 500lbs of trq so it should be suffiecient for the MLs 360lbs
Not sure if this is something any other owner has done... So I guess Im the guinea pig
