Motor Mount or ???
While waiting for the repair, I visited with the accessories manager, who's always treated me great. I mentioned the symptoms, and while he had nothing to do with the repair, he later checked with the service techs and reported that while the motor mount was fine, its bolts had somehow worked loose and dropped out!
I mentioned that scenario to the service manager handling the situation (a backup to my usual svc mgr who was out sick) and he would only say that they had identified the problem and the car would be ready shortly.
When I received my invoice (covered under warranty, of course), there was no mention of motor mounts or motor mount bolts. Instead, it says "Left front sway bar nut is loose, need to R&R LF sway bar nut and apply Loctite to thread."
Anyone ever had a similar experience? Seeing the driver's side twist up 8-10 inches out of the engine compartment when the service tech gunned it sure sounds like a motor mount problem to me and nothing to do with loose sway bar nuts.
Regardless, whatever was done, the symptoms have disappeared. On the way home I started off with part throttle launches, increasing to full bore, with no trace of the "knock." Knock on wood things stay that way - this week is the one year anniversary of the beast and apart from this isolated incident, it's been trouble-free.
Anyone with like info, please post and I'll update my experiences accordingly.
Regarding what showed up on the Invoice, I'd press them as to the real reason why. No way a sway bar affects the motor, when revving it or not, while that motion you describe is exactly how you diagnose a broken (or in this case, unbolted) mount.
Problem no doubt is a motor mount problem IMO.
Have you had any work done on the motor whatsoever?
I had the dealer change out a bad sensor when my car was brand new and one year later had one of the fan belt pulleys get loose and almost fall off. I can't imagine that coming from AMG like that. Must have been an incorrectly torqued bolt during that repair. Bet you that's what happened.
). Definitely agree it was motor mount related, but why they'd put it down as a sway bar nut problem baffles me.Likely scenario is under-torqued motor mount bolts, but I'm surprised the problem never showed up before, especially at the track. Remember, while the engines are built at Affalterbach, they're installed in the chassis at Sindelfingen, along with the non-AMG M-B's.
:v
