"REST" Menu Feature
Old Jan 19, 2006 | 05:41 AM
stevebez's Avatar
No longer stock '06 E55, A3 3.2 Quattro, GLE 400d, R107 280SL, Golf Polo
"REST" Menu Feature
Dunno if you guys know of this already but I find it usefull to view some stuff...
In particular
-coolant temp
-engine rpm
-speed
To do this press "REST" on Thermotronic for 5 secs and a diff dispaly comes up use the temp toggles to move the left values up and down (that refers to the menu number) the right value is the metric data. There are around 40 diff codes here, but the most usefull one for me is 06 - coolant temp. Much more accurate to view than the stupid bar graph.
01 In-car temperature sensor.
02 Outside temperature sensor.
03 Heater core temp, left.
04 Heater core temp, right.
05 Evaporator temperature sensor.
06 Engine coolant temperature.
07 Regrigerant pressure in bar (e.g. '4' is 4 bar).
08 Refrigerant temperature.
09 Not used.
10 Heater blower control voltage (normal 08-6.0, meaning .8 to 6 volts).
11 Emissions sensor voltage (to detect atmospheric gases and recirculate interior air).
12 Sun sensor voltage (to shift airflow in car).
20 Control current for auxilliary fan (electric fan on radiator, given in milliamps or mA).
21 Engine speed (x100).
22 Road speed (km/h or mph depending on installation).
23 Battery voltage at terminal 58d (as a percentage of total voltage, e.g. 99.0 = 99%).
24 Battery voltage (e.g. 12.8 = 12.8V).
40 Climate control software version.
41 Climate control hardware version.
Rgds Steve.
P.S. to get back press REST agn.
Old Jan 19, 2006 | 07:28 AM
jparch's Avatar
2018 E63S wagon, 2016 GLE350d, GLE450 on order
nice info
Old Jan 19, 2006 | 08:29 AM
Fikse's Avatar
STS,FGT,12C,P85D,M4
where is this button? "REST" on Thermotronic
Old Jan 19, 2006 | 08:41 AM
stevebez's Avatar
Yep "REST" in the thermotronic module.
Data displayed in the thermotronic display.
Rgds Steve.
Old Jan 19, 2006 | 10:35 AM
Can Drive 55's Avatar
2005 E55
Not sure whre the thermotronic module is. You don't mean the "Rest" button by the climate control buttons, that was discontinued, do you?
Old Jan 19, 2006 | 11:12 AM
Fikse's Avatar
STS,FGT,12C,P85D,M4
heh, no idea either... physically where??
Old Jan 19, 2006 | 11:51 AM
stevebez's Avatar
Dunno about discontinued ...but its in my '06 E55 .... part of the top centre console where all the a/c controls are.
Where you set the temps and A/C fan speeds etc ... there should be a button "REST".
Rgds Steve.
Old Jan 19, 2006 | 01:17 PM
BenzoBoi's Avatar
Super Moderator
W221
so what can you do once you get into this little menu? Is it just for looking at or can you change anything?
Old Jan 19, 2006 | 01:42 PM
jangy's Avatar
2015 S212
Wasn't the rest feature dicontinued on US models. Mine is an '05 E55, with no rest button
Old Jan 19, 2006 | 02:03 PM
Jspeed's Avatar
E63 biturbo
Interesting .... you can actually change the values of the data on the right side too. Wonder what that does??
Old Jan 19, 2006 | 02:39 PM
pas's Avatar
pas
2007 S65, 2005 Nissan Armada
is there a way to access this information on '05's that don't come with a "rest" button?
Old Jan 19, 2006 | 03:00 PM
Tony007's Avatar
2010 ZR1 2011 JGC Overland 2013 ML63 on order
Ok, on the CLS's there is a blank space for a button on the A/C controls panel located right between the driver's side up/down temp control button and the "small/lower fan" speed button. It's just a dummy blank button.
Is this where you are referring to?
Old Jan 19, 2006 | 03:03 PM
Tony007's Avatar
I want to know how to access this stuff if you don't have that button on the Thermotronic panel.
Maybe they don't think MB owners care enough about this information and deleted this feature?
Old Jan 19, 2006 | 05:46 PM
dsc's Avatar
dsc
2004 E55
I have a 2004 E55. The actual AC off button says REST under the AC off title. I pressed that button for 5 to 10 seconds and sure enough that screen came up. Mine came up with 00 which I could scroll to 99 with the drivers temp adjustment. I can change each of the 00 to 99 values with the passenger temp control. There is no description of what 00 to 99 is.
Stevebez, where did you get the directory descriptions of the numbers from?
I called the Mecedes help number, (I have never found then to be useful) and they couldn't tell me what this menu is or what it is used for. They just explained the "rest" feature to me. They thought maybe it was some kind of diagnostic function and not to mess with it and get out of the menu right away.
I sure would like to know what these 100 parameters are and what changing them does.
Old Jan 19, 2006 | 06:25 PM
pas's Avatar
pas
I think the "rest" button is only on 2003 & 2004 cars. The 2005 and up don't have it, but there must be a way to access that menu...
Old Jan 19, 2006 | 06:48 PM
dsc's Avatar
dsc
2004 E55
pas,
Have you tried holding in the AC off button for 10 seconds?
Old Jan 19, 2006 | 09:00 PM
enzom's Avatar
2005 E55
I have an 05, and have a REST button.
But I pushed it for 10 seconds and nothing happened.
Old Jan 19, 2006 | 09:17 PM
Tony007's Avatar
My car is out getting Kleemann K2 or else I would have already tried it..
Can someone please try and hold the A/C off button for 5-10 sec and see if anything happens..
Old Jan 19, 2006 | 10:20 PM
pas's Avatar
pas
I tried holding all kinds of buttons sometimes together and nothing, oh well...
Old Jan 19, 2006 | 10:24 PM
jangy's Avatar
2015 S212
Damn. I was hoping we had a new gadget to play with!
Old Jan 20, 2006 | 03:31 AM
stevebez's Avatar
Hi Guys sorry you not having much luck here but I find this mode really usefull... I got the stuff from another forum where all this was listed. Its a pity that it is an A/C diagnostic mode (all the metrics relate to A/C performance) and not a real feature - that would be neat. Its a bit of a nuiscance that the left value is just a number in the list of the data and not a proper description. The value on the right is the output data...
Ill get you guys a pic this w/e ... I only really use it for speed and coolant temp.
Ordinarily the display just reads the left and right a/c temp settings.
I dunno why the REST feature is not present on some models (yes its the button left of the "lower fan" button) - but mbe its only cars with thermotronic - but isnt that standard ?
Rgds Steve
Old Jan 20, 2006 | 08:23 AM
sprins's Avatar
G55, SLS, smart eq
Hi,
My 02BY, 03MY S55 also has this feature. But mine shows 100 codes (00-99). I wonder where I can find the exact explanation, and what codes are changable...
Old Jan 20, 2006 | 08:28 AM
stevebez's Avatar
The data are sensor outputs - ... dont think you can change them ...??
Rgds Steve.
Old Jan 20, 2006 | 09:58 AM
vrus's Avatar
2003 E55 AMG
stevebez,
Awesome find!!!! I personally thank you becuase I've been looking for a way to get at this data while driving without having to use my datalogger.
I am going to try this tonight on the way home.
Once again, thanks for finding this little gem!!
Old Jan 20, 2006 | 04:02 PM
stevebez's Avatar
No probs vrus - happy to help ... if you find the code for oil temp or IAT's that would be fabulous !
Rgds Steve.
