Aux Input In Comand
Old Feb 17, 2006 | 09:30 AM
leepy55's Avatar
2008 S63
Aux Input In Comand
sorry for the stupid question ... but where is the input hole in the COMAND unit to plug in auxiliary equipment?
Is the COMAND unit iPod-friendly?
Thanks in advance!
Old Feb 17, 2006 | 09:44 AM
vrus's Avatar
2003 E55 AMG
There is an AUX in connector on the back of the command. The newer cars (late 2004 and on) have the connector already wired and sitting in the glovebox. It's a little hard to spot because it is covered in a black plastic surround. Its at the top left side. If your car is 2003 - early 2004 then you probably dont have the connector in the glovebox.
You can purchase it for $40 and install it yourself.. takes about 1hr to take everything apart to get to it. The hardest part is fishing the wire between the command area and the glovebox area.
Thanks in advance!
Old Feb 17, 2006 | 09:53 AM
leepy55's Avatar
2008 S63
thanks so much vic. btw
is it iPod-compatible?
Old Feb 17, 2006 | 10:05 AM
vrus's Avatar
2003 E55 AMG
You can plug anything you want into it as long as you have the right adapter.. You should be able to put your iPod into it.. Only issue is that you will have to control what gets played by pushing buttons directly on the iPod.
For your 2005, they have an iPod Integration kit which allows full control of the iPod through the car's stereo/steering wheel.. Its $400 from what I remember but that gives you a fully integrated solution.
Old Feb 17, 2006 | 10:48 AM
Fly Low's Avatar
w211 E55
Can I get the same integration kit for my 2004?
Thanks,
Old Feb 18, 2006 | 12:19 AM
OzE55's Avatar
2003 E55
I have a 2003 (Euro spec car - Australia) and its not in the glovebox.
Where on the back of the COMAND?
Can you get to it without putting the centre console apart?
What plugs into it?
picturs would always help.
thanks.
Old Feb 18, 2006 | 09:33 AM
chem0's Avatar
2004 E55 AMG
which is the right adapter for ipods?
Old Feb 18, 2006 | 01:05 PM
Ducman's Avatar
Black/Black E : Pewter/Black G Wagen
3.5 mm male to male connector that you can buy at Radio shock for $4.00 or your local walmart, Belkin has them too but for much more.
