I need some help guys...
Old Feb 22, 2006 | 10:07 PM
bigc's Avatar
'05 E55, HRE 847R's black centers, black grille
I usually do more reading than posting, but this time I need some help. I was driving down the road today and my gas gauge starts blinking and my display reads check gas cap. I pull over to check it and it's closed. I turn the engine off and restart the car and the signal goes away. I figure it was just a malfunction. This happens twice. Then, a couple of minutes later my comand gives me a reading that says, voltage too low, turn on engine or comand will shut off in 3 minutes. I hit "ok" and the warning goes away. 2 minutes later it gives me the same reading but this time says it'll shut off in 10 seconds. I hit "ok" this time and it shuts off. No radio, no comand. Now my driving display just reads "audio off". I can turn the comand back on but it shuts off after a short time. I called the dealership and they told me it might be an alternator problem. Anybody else got any suggestions/opinions?
Old Feb 23, 2006 | 08:22 AM
Rock's Avatar
Administrator
Drives Slowly
I had a similar experience after my battery was accidentally drained. The low voltage light came on and the command system shut down.
I would also not be surprised if the alternator is to blame.
O.T.- Can you post a few pictures of your wheels. I'm trying to find the right ones for my car.
Old Feb 23, 2006 | 08:32 AM
Eddie Knopp's Avatar
2013 E 350, 2012 GLK 350, 2012 C300 4matic
could be the battery control module there was a service advisory on it - it's a pain in the a** but safe - quick fix
Old Feb 23, 2006 | 09:21 AM
corgiman's Avatar
E55
There have been some problems with battery control modules that give this sort of message. I had the same problem after I left my lights on and they replaced the module. Also I understand that you must strictly follow the instructions when jump-starting the car.
Old Feb 23, 2006 | 02:39 PM
bigc's Avatar
I'll keep you posted
Thanks for the tips guys, I dropped it off at the dealership this morning. My car had a hard time getting there. When I pulled in the bay the "alternator/battery shut off engine" light came on. It wouldn't even start after that. I'm assuming it's the alternator. They had to jump it just to get it to service. I'll keep you guys posted.
PS: Rock, I'll try to get some photos up but it might be a couple of days, pretty hectic rest of the week ahead.
Old Feb 23, 2006 | 06:40 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
Mine did the exact same thing when it was about 6 mos old. Module was replaced as I recall.
