Ways to tune an E55
I have just bought a 2005 E55 from a local MB dealer. Unfortunately, in Saudi Arabia, the place where I work, they do not have Brabus, Klemman or any other MB tuning company.
The local MB dealer suggested that they can send the computer board to AMG in Germany for reprogramming. This will reserve the warranty, add 30 hp and remove the limiter at a cost of US$ 2,800.
In the neighboring country, Bahrain, the MB dealer is also a dealer of Brabus. They asked for US$4800 for a K1 Package, which includes; reprogramming the board and replacing a pulley and a belt.
I am just looking for the simplest, cheapest and safest way to tune my black beast.
My two questions are:
1) Which pulley they going to replace and how this will influence the engine horse power? what the maximum speed the car can reach in this case?
2) What could go wrong if I go with AMG tuning, i.e., reprogramming without changing the pulley and the belt? what the maximum speed the car can reach in this case?
In any case if you really are going to go 186 MPH then make sure your tires are rated for that much speed!!! ( "Y" Speed Rating = 186 MPH) There is no Tire that is manufactured and is DOT approved for speeds faster than 186 MPH.
The ECU reprogramming changes the ignition timing advance curve (more ignition timing advance) and the fuel curve. The larger crankshaft pulley turns the Supercharger faster and therefore forces more air into the motor, which will produce more HP. Both of these Mods. are safe for the Motor if Kleeman, Renntech, or Brabus Mods. are used and a competent installer is used.
Are there roads over there that are long enough and that are not to busy for that kind of speed?
- Bob
Otherwise 186mph (Y rated) is your limit!
Rgds Steve
Rgds Steve.
- BobThanks for the information
Rgds Steve.
Regardless - what does it cost from AMG? (I presume then it has ALL the campaigns applied and is up to date in every way).
Really? I did not know that. That sounds very appetizing.
I think since you leave in KSA and gets quite HOT there...
It would be good idea to add EVO colling package...Will give around 15-20 HP and you car would run much cooler...
Cause with chip and pullies the Boost raised and temperature in manifolds rises as well...Running on a HOT day at max speed could be Dangereous with this set up...
All depnds on money you are ready to spend...
