Plzzzz Help!!!
You can run it into the fuse box on the left side of the engine compartment, around the circuit board, down and into the drivers footwell, across under the dash around the console to the passenger side. It's not easy, but can be done. This will only work with a small diameter hose or wire.
Glenn
Glenn
