Location of Horn Fuse
If you look into the car manual you will find where is placed the fuse diagram book. It is a little paper where is mentioned all the fuse by number and name. In my E class 2010, the little paper with the fuse diagram is hidden in the trank under the extra wheel.
Horn stop working, this is could be mainly due to three raison :
- Horn Fanfare Fuse is blown
- Horn relay
- Horn it self not working
In Mercedes there is a Low and High tone Horn, if both not working than maybe is the fuse, check the fuse diagram booklet and change it. If the fuse is okay then check the Horn relay.
If only one Horn is working then I expect that the problem comes from the Horn itself, check the defective Horn get the part number and change it.
Good luck
- Horn relay
Good luck
