Evotech Transmission ECU...
Well got a reply from Germany...
They said they can make E55 into 700 HP range and do transmission ECU to transfer more power at 6800 to the wheels...
This is what E55 missing...more power at the wheels at high RPMS !!!
Here is the DYNO sheet of they sent ME (CL 55K):
At that speed dont know how tranny ecu is going to do anything exciting ... With a lock up torque converter dont know what tranny ecu could do other than alter shift speeds / pattern of shift....? More info from them would be usefull - seems like there may be a shoter diff lurking there somewhere...?
Not all Germans speak good English...
I think they meant more Wheel Power up to 6800...on TOP...
Will lety you know more when I get more info...
What does the transmission have to do with the RWHP measurements? It is the ECU that controls the moderation of torque and pig-rich fuel mixture at higher RPMs. I don't understand it. Are they disabling some factory torque management system that pulls timing and slows things down on a full throttle upshifts to lessen strain on the tranny?
04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
Well... they called ME them selves and asked ME what I want to be done to my car...and I said I jsut need engine ECU and transmisson ECU and they said We only used our ECU with our prodcuts, so I said OK I will get my ECU from someone else...
