Another Lowering Question
The low setting engaging automatically when you go over a certain speed (~120km/h or whatever it is).
My question is: if you have your car lowered already via whatever method, then is it possible that this high speed automatic lowering may drop the car too low? And does anyone know how much the car drops at high speed?
Secondly (apologies if this has already been answered) is the high setting affected by the lowering? So that if you lower it 25mm, then hit the raise button, it will be 25mm lower than the original high setting?
Reasons for above is that i was thinking about max lowering the car suitable for slow cruising, and then leaving it on raised for normal driving, which would bring it to a lowish or near stock sensible height. Is that feasible or would i just be eating tyres out due to alignment probs at one of the heights??
thanks
Rudy, So your saying that with your renntech module, the high button still brings the car up to its "factory" high position?
To those with other modules such as Kleemann module, is it the same with your cars if you hit the high button?
