Dyno in Columbus Ohio
Old Jul 13, 2006 | 01:16 AM
gianster's Avatar
05 E55 Pewter K3 w/ LSD
Does anyone know a reputable shop to get a dyno done in the Columbus Ohio area? I had my 05 k3 car dynoed twice and both time the numbers were all over the place on each pull. They used dynojet winpep7. Is this a good software? What are your favorites? I don't know if they don't know what they're doing or if it's the software or what. Cory from Kleemann told me to find a place and he would call them before doing it to give them full instructions (dynomode, what gear to be in, etc.) to get the most accurate reading. I have attached a sample. Cory said the Torque number is probably out of wack. There is a huge jump in Torque early on and goes back down. Is this normal? I forgot to add that the hp figures are at the wheels not crank.
Thanks,
Gianni
Old Jul 13, 2006 | 08:32 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
DynoTune Motorsports
Mobile Dynamometer Service
Columbus
Tel: 614-778-7823 (Howard), 614-778-8984 (Brian)
Website: www.dynotunemotorsports.com
Maximum Street Performance
485 Turnstet Lane
Columbus 43228
Tel: 614-272-7472
Old Jul 13, 2006 | 10:03 AM
vrus's Avatar
2003 E55 AMG
Its not the dyno that is the problem, its the setup!
You HAVE to put the car in Dyno mode and you HAVE to run in 'M' Transmission mode in 4th gear.
Those crazy lines you see are the transmission shifting or the ESP light blinking and cutting power.
Old Jul 14, 2006 | 02:11 AM
gianster's Avatar
Thanks vrus. I'll pass on the info to the dyno operator.
