highest octane gas for k3 cars
Old Jul 17, 2006 | 08:46 PM
gianster's Avatar
05 E55 Pewter K3 w/ LSD
100 octane in K3 cars
I have located a sunoco that has GT unleaded 100 octane used for street use. If I use this gas consistently, will the ecu learn to adapt to this and increase in power. Or is kleemanns ecu only good for a certain number of octane. Any comments good or bad?
Thanks,
Gianni
Old Jul 18, 2006 | 02:45 AM
Grumpy666's Avatar
Mix it 50/50 with your standard gas. That will give you a little more octane than the ECU is tuned to use, but it will provide you with a measure of safety against detonation. If you run it w/o mixing, you will probably lose power. This has been discussed several times. Try searching.
