Cracks on the brake disc!
2015 S212
Originally Posted by L8Apex
As stated by others, this is normal with cross-drilled rotors. It has happened with every car I've owned. Not to worry. However, if you want to upgrade the rotors with a better performance-based application, go with slotted rotors. (see evosport) They are much more efficient with dissipating heat and gases generated by heavy braking. Both of my racecars had slotted rotors.
Originally Posted by jangy
EVO rotors are not cryo'd. Does anyone know the cost on this process?
Also, AGAIN..is there any other options for us on getting JUST replacement rotors and keeping our calipers?
Do you have another source for the slotted rotors? Thanks for the PM.
I'm curious.. if drilled rotors crack like this... and slotted tend not to (other than shatter)... does a cross drilled AND slotted rotor fare better or worse crack-wise over the long haul? I would imagine worse since you're adding yet another wrinkle to the overall struture, but who knows.
I've been holding out for good aftermarket cross drilled and slotted rotors for a while now...
Loren
Loren
1 Post
04 C320 Coupe MT
To quote the WIS: (workshop information system)
"Ventilated, brake discs with perforations and without perforations do not have to be replaced if the hairline crack length is a maximum of 25mm.
On perforated brake discs the hairline crack length including the hole diameter is to be measured"
So, the discs don't have to be replaced if there is a crack, however if it looks like the picture above I would replace them in a minute!
#32
2015 S212
Tirerack carries Brembo slotted rotors. Not sure if they have them for our cars though.
#33
Actually, I wouldn't be too worried about these hairline cracks. They're mostly superficial, and just comes from fairly hard use (but intended use). I have many hairline fissures on my 996TT, which are still using stock rotors. I track the car quite often. Like the other poster mentioned, if they are beyond a specific length/depth, then that's when you need to replace them.
#34
Originally Posted by //AMG55lover
Every more or less 30K kilometres, I need new brakedisc's because of those dangerous looking cracks!
Is this extreme and dangerous or just normal?
#35
2007 S65, 2005 Nissan Armada
Originally Posted by adx
Correct, EVO rotors are not cryo'd. I got them cryo'd at www.300below.com and it cost about $150 for all 4 rotors.
Have you noticed any difference with the rotors being cryo treated? Have you braked real hard from high speed repeatedly or done anything to "abuse" the rotors that might lead to surface cracks? I was told by the guy at 300 below that cryo treatment would solve the craking issue with the stock rotors just wondering if you have any actual experience to back it up.
#36
#37
2003 C230 Coupe
Hole cracks on rotors can be dangerous.
Dude you would think that the holes would be helping in reducing heat Huh?
It looks like your rotors are cracking by a combination of structural degradation by the holes plus an apparent overheating.
Are you using the brakes too hard all the time?
Are the metal surfaces that make contact between the pads and the caliper bracket well lubricated and cleaned up of rust?
I recommend you try the new rotors that have dimples instead of holes.
I have seen one that had dimples and slots. It looked nice and reasonably priced.
I just had my front pads replaced today. I used Akebono's ceramic pads.
The original rotors still looked good (no lips) and quite shiny so I left it alone.
#40
I had this...replaced them at 25 km...They are not that expensive...I think it happned after you get you brakes hot and then hit water splash or clean you wheels with chemicals...
#41
2003 C230 Coupe
another thing you have to consider is that given the high cost of some of these rotors, there is a posibility that depending on where you buy your parts you could be get counterfeit stuff from Northern Asia, if you know what I mean. Those rotors don't come with serial numbers or fancy stickers that let you know when you have been taken.
Try buying these parts as anything else for your cars from reputable dealers such as tirerack or any others that advertise here.
I would stay away from ebay and other shady fly by night web sites.
You would never know what you are really getting there.
Your car costs enough for you to be trying to skimp on a few dollars on parts.
Specially when you are already saving a bundle on DIY stints.
Have a great one
Have a great one
#43
E55
I had used www.300below.com many years ago to cryotreat my Baer rotors. You can have the rotor send there straight then treated before coming to you. Would I do it again, NO. After road racing for four years and getting my professional race license, I would still not do this. Most people at the track will put in the biggest but cheapest rotor you can find. Then replace it when you need to.
Back to topic:
As stated, the cracks looks fine to me (some starting to look pretty deep and big though). I would not hesitate to drive it at all. I have raced rotors that look like that. I would only worry if it has cracked through and extend to the end.
Back to topic:
#44
someone mentioned that brake rotors seem to be made out of any old pig iron.... indeed thet are as cast iron provides the best heat dissapation/ duarability mix needed to survive this much abuse for this long. think about it.
assuming a perfect system, your car can stop quicker than i can accelerate, meaning your car has more "stopping horsepower" than "acceleration horsepower" any yet only your engine has a dedicated active cooling system, not your brakes...
