How do you change to 93 octane setting?
There are also other settings for fuel enrichment where you can make the mixture a bit richer or leaner.
I havent fiddled with them because my car already has a modified ECU file and those settings are only recommended to be changed on a STOCK ECU file.
P.S. screenshots of star diagnostics: http://www.infopages.net/renntech/fu...ings/index.htm
the sitting for ignition in MB star or DAS is clearly mentioning ( RON 89, 91 and 93) European numbers which is equal to ( MON 85, 87 and 89) American Numbers so setting ur ignition to 93 RON will actually reduce the ignition timing which will reduce power.
