sbc Noise From the Woofer...?!
Guys,
From the above subject, note that I heard noise from the SBC work "vibrate" and the noise effect on the rear speaker "Woofer".
I thought may be it's from something else, but once I removed the wire of the woofer the sound goose.
I connect it again then it comes once the SBC work "Vibrate".
I change the woofer and I notice the noise still coming.!
Any one had the same problem? How did you solve that?
Regards
Regards
Did you replace the factory speakers with an after-market system?
Edit: Never mind - I did a search for you and found this:
https://mbworld.org/forums/showpost....13&postcount=4
Yes i did replaced the woofer... note that even before i replace the woofer i got that noise always.... and until now..
1 Post
E500 "The Diplomat" W211
I need help with this too. The attached forum didnt really have anything to do with the issue. The Subwoofer amplifies the sound of the SBC unit through the speaker itself. SO ANNOYING!
