Strange Engine noise
Old Sep 26, 2006 | 03:04 AM
mbamg06e55's Avatar
06 E55 SOLD, 89 300 SE 375,000 miles
Exclamation Strange Engine noise
When the car is idling when at operating temps, the engine sounds to some degree like a diesel. Quite a bit of clatter coming from the bottom end of the motor. It basically sounds like the bottom end is going to fall out.
I have taken in to the dealer and they say that the noise is normal.
Anyone elses cars make this noise.
Daryoosh
Old Sep 26, 2006 | 03:53 AM
FlyByNight's Avatar
05 E55
Mine has always been oddly rough and sandy sounding too... they told me it was normal as well. Sounds like a bunch of old bearings beginning to die, with some sand thrown in...
Old Sep 26, 2006 | 07:11 AM
PA55AMG's Avatar
2010 Range Rover S/C 2010 Land Rover LR4 HSE Lux Plus 2007 BMW R1200GS
My S55 sounds the same way. I think part of the noise is piston slap. It seems that all of these new cars have very short piston skirts for efficiency and power and that can definately add some knocking/rattle type noises.
Old Sep 26, 2006 | 09:15 AM
corgiman's Avatar
E55
Same here - makes the engine sound cheap.
Old Sep 26, 2006 | 10:41 AM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
You should hear how the "yowling V10" on my M5 sounds at idle, like a friggin civic. It buzzes like a lawnmower.
Old Sep 26, 2006 | 10:46 AM
vader's Avatar
04 E55
Mechanical music !!!
Old Sep 26, 2006 | 10:51 AM
jangy's Avatar
2015 S212
Check where the noise comes from, how loud it is, and how long it lasts. If it is in the head, then it is likely "normal". Our cars run synthetic oil, which takes a sec to get circulated since it drains so well. If the noise is indeed in the bottom, thne that would be the crankshaft bearings and mine is quiet there. BUT, mine is noisy in the head at startup. I'd say get it documented that it is normal. NOT just an I asked and they said. Get an invoice that says what the customer describes and a response from the dealer. That way, you are protected later just in case. These cars are VERY noisy. They are also pretty rough at idle. Just how the beast is.
Old Sep 26, 2006 | 11:51 AM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
I had a "machine gun" type noise from my and it tuned out to be a loose pulley. MB covered it under warranty. I'm not sure if this is what you're referring to, but it wouldn't hurt to get checked out.
Old Sep 26, 2006 | 01:41 PM
Grumpy666's Avatar
Is this a recent addition or has the noise always been there?
Like the sweet sounds of a Duntov 30/30 solid lifter cam.
Old Sep 26, 2006 | 02:13 PM
Vetluver's Avatar
SL 65 AMG and E63s AMG
If you beautiful sound out of motor you need a small block Chevy with a mild cam. Of better yet a RAT motor. They both make symphonic sounds IMHO.
Old Sep 26, 2006 | 05:45 PM
mbamg06e55's Avatar
The noise has always been there. Sometimes its just louder then other times.
Old Sep 26, 2006 | 05:53 PM
newton22's Avatar
BMW E39
Or a Lamborghini Murcielago at idle. mmmm.
Old Sep 26, 2006 | 06:04 PM
Grumpy666's Avatar
If you're really concerned about this and the dealer is shining you on, get yourself an engine stethoscope. They're fairly inexpensive and are very helpful for locating engine sounds. I used to use a long-*** screwdriver with the handle jammed in my ear.
Pay particular attention to idler pulleys and anything with rotataing parts (supercharger, AC compressor, etc).
Old Sep 23, 2009 | 09:14 AM
preston27's Avatar
2006 E55
I have the same noise and same "normal" answer from the dealer. I was at Renntech and heard a 55 that was not making the noise. I hope you guys post a solution to this issue.
Thanx
Old Sep 23, 2009 | 12:15 PM
preston27's Avatar
2006 E55
Did you find out what that noise was?
Old Sep 23, 2009 | 12:25 PM
TopGun32's Avatar
any MB engine.. is usually pretty noisy.
Even the C300 and 350 when compared to Honda or Toyota.
The V8's..same thing... compared to Lexus
The good thing that BMW and Audi engines are pretty noisy too.. so I guess its a German engineering thing.
Old Sep 23, 2009 | 12:49 PM
Harsany's Avatar
2006 E55 Black on Black
Check your belt tensioner pulley and the pulley beside the tensioner, then can start to go and causing rattling sounds.
Old Sep 23, 2009 | 02:13 PM
harjothundal's Avatar
05 e55
Originally Posted by preston27
I have the same noise and same "normal" answer from the dealer...
same here
Old Sep 23, 2009 | 06:51 PM
Vader13's Avatar
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
I had a funky noise, it sounded rattely like the C230 crappy little motor. Problem was a Supercharger Belt Tensioner cleared under warrenty, I guess it's around 800.00
