command screen brightness
Old Nov 9, 2006 | 09:08 PM
Fleebee's Avatar
S211 AMG
My command screen brightness is not automatically changing to night time mode when it's dark outside. If I manually set it to night mode then it will switch over so the problem has to be external to the command. I would assume there is a light meter/sensor that isn't working. Is there a quick fix or is it another trip to the dealer?
Thanks in advance.
Old Nov 9, 2006 | 09:42 PM
Kev04C320's Avatar
'09 911 C4S
do your headlights turn on in auto mode when it's dark out?
Old Nov 9, 2006 | 10:05 PM
Fleebee's Avatar
S211 AMG
The headlights work as they should. The problem surfaced after I had a detail if that's any help.
Old Nov 9, 2006 | 10:44 PM
Kev04C320's Avatar
'09 911 C4S
water got into some sort of a relay? coz I think the COMAND and the headlights share the same light sensor
