E55 Acceleration Problems
Old Nov 20, 2006 | 10:24 AM
Noredline's Avatar
2015 C63 AMG 507
Hi all, I have a 2005 with 41K on the odometer. It has been sitting at my buddies house for 3 months since I got the CL65 . Picked it up Saturday to clean it up, I'd like to sell it. Anyway, I had it in to the dealer back in August because it felt a little weak, and was making what sounded like early detonation sound (ticking/crackling) on acceleration. Anyway, it is worse now, it runs fair for about a half hour, then if you tip down to second at about 50, it should normally whip your head back in the seat, but it does not. I get all the sound, and none of the thrust. Has anyone had this issue? It almost feels like the SC is not engaging if that is possible. Your assistance is appreciated. I am bringing it to the dealer next week and any info you may have would be helpful.
Thanks,
Dave
Old Nov 20, 2006 | 10:28 AM
PDC's Avatar
PDC
2006 SL65 ///AMG - GONE BUT NOT FORGOTTEN: 2005 E55; 2002 ML55; 2001 CLK55; 1992 BMW 850i; 1991 M5
SC Clutch or IC Pump
Sounds like either the SC Clutch or the IC Pump. Both of which should be easy to diagnose and eaqually easy to remedy.
Old Nov 20, 2006 | 11:41 AM
Noredline's Avatar
2015 C63 AMG 507
Thanks for the input, I will let the dealer know.
Old Nov 20, 2006 | 10:00 PM
bigc's Avatar
'05 E55, HRE 847R's black centers, black grille
I agree
Sounds like the IC pump. I had the same problem. When I would punch it there was no power. They said it was because the SC was getting too hot because the IC pump was bad.
Old Nov 20, 2006 | 10:49 PM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Thanks,
Dave
IC pump for sure! You can tell very easily... it feels like a slug without the S/C not engaging..
Old Nov 21, 2006 | 01:56 PM
Noredline's Avatar
2015 C63 AMG 507
Thanks guys, yeah, definitely feels like a slug. I will let the SA know that's what we think and go from there. I am also having the "chirp" at take off, SC belt I believe, as well as that early detonation sound as well. Hopefully they can get it all done and they are easy fixes.
Thanks again for your assistance, greatly appreciated.
Dave
Old Dec 1, 2006 | 05:40 PM
Noredline's Avatar
2015 C63 AMG 507
Update...
Hi all, well I had the IC pump replaced the other day, and the car is a totally new beast. It is stronger and faster than ever before, like a new car with miles!! Traction control is like a Christmas Tree through first and second gear, incredible power. Goin to the track tomorrow with RenntechV12 so it will be interesting to see how she does. Thanks again for your advice and input
Dave
Old Dec 1, 2006 | 06:23 PM
zdkdeeier493's Avatar
Glad to hear everything worked out. Its always a nice surprise after the pump is fixed
Old Dec 1, 2006 | 10:45 PM
Yes glad to hear that everything is fixed.
Old Dec 5, 2006 | 10:59 PM
Tectite.Metal's Avatar
c32 AMG
Quick question
Sorry I know I am not in the right post but since its a fresh topic..
How do u tell if your SC is failing or the IC pump. They are so interconnected..
Old Dec 6, 2006 | 09:13 AM
You can tell very easily. Upon acceleration, if you car feels like a slug, I mean if it doesn't kick you back in your seat, you super charger is not engaging. And most likely you ahve an IC pump issue.
Old Dec 6, 2006 | 01:41 PM
c32 AMG
Humm Can the IC pump begin to fail
Humm I had a MB specialist run a diagnostic and i had my SC clutch come back with 10 errors. I know she has lost some kick to her but she does not run like a slug. NOW sometimes when i accelerate i don't get that kick back.. Its off and on..
Could that be signs of the IC pump beginning to fail.
Old Dec 6, 2006 | 02:07 PM
Most likely the IC pump is intermittently failing! Get it checked out... They should replace it if its intermittent..
Old Dec 7, 2006 | 12:09 PM
c32 AMG
Thanks sooo much.. appreciate the help even though I am not E55er.. I wish i was... but I love my C32..lolol..
And Merry X-mas..
Old May 28, 2014 | 01:19 AM
demetaktak's Avatar
04 E55 w211
hi all,
got the same problem last night. SC was on and off, embarrassing me a few times but when its fully on, its a monster. i'll take it over to the dealers over the weekend... see how it turns out.
Old May 28, 2014 | 01:28 AM
E55Freak's Avatar
2005 E55 silver
attention all newbies...if you feel your car is not performing at it's peak just replace the IC pump. $100 and 30 mins of your time is all it takes...it's extremely easy to swap out...then if you feel its still feeling sluggish diagnose further..
Old May 28, 2014 | 09:58 AM
demetaktak's Avatar
04 E55 w211
guys, as i live abroad, it is supper expensive to find IC pump cheap and will be better to have it shipped. anybody knows where i can order it from online?
thanks in advance.
Old Jan 21, 2015 | 03:34 AM
zhmorrow13's Avatar
W211 E55 AMG
Mine seems to accelerate alright, but when I let off the gas and coast my car seems to have excessive drag...almost feels like a downshift without it actually downshifting or RPMs rising...
Do you believe that changing this IC pump could solve? 140k 05
Old Jan 21, 2015 | 06:00 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
If your IC pump is bad you will experience a significant decrease in power after back to back accelerations
Old Jan 21, 2015 | 09:14 AM
kponti's Avatar
E63
That's because the car stays in gear after you let off and you begin engine braking. Sets you up to accelerate in the right gear of you were to floor it again
Old Jan 30, 2015 | 12:59 PM
Crissus's Avatar
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Yes exactly. Its AMGs so called "Speedshift" gearbox system for the "old" AMGs. It furthermore uses the lockup clutch in the torque converter for that effect.
They just drive different (read "better") than the older torque converter boxes without lockup clutch
